Old 05-07-2008, 09:03 PM
rairigh915 rairigh915 is offline
99 gp gt
99 gp gt 3800. My scanner keeps reading codes po133(o2 circuit slow response bank 1 sensor 1) and p1133(HO2s/O2S insufficient switching sensor 1 bank 1).I just changed both 02 sensors and EGR. Could MAF cause these codes also? Or did I possibly get a bum Bosch O2 sensor?
Old 05-07-2008, 10:17 PM
Will Help Will Help is offline
Re: 99 gp gt
Might check for possible wiring problem before you start swaping parts.
Old 05-08-2008, 04:42 AM
Re: 99 gp gt
O2 sensor wiring?
Old 05-08-2008, 05:45 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 99 gp gt
I assume you reset the codes after installing the new sensors? If you did, then strike up another junk Bosch oxygen sensor.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-08-2008, 08:18 AM
OJ_ OJ_ is offline
Re: 99 gp gt
Exhaust leaks will also generate both of the codes, make sure the sensor is screwed all the way in and tight. I would also try swapping it out as well.
2001 Silver GTP Coupe
Self-Tuned - HP Tuner, 1.9s, 105s, Coated Pacesetters(no cat), Poly MM, EGR del, ZZP 1.0 PCM, ZZP MPS 3.25-3.4, AL 104s, Wizair, TBS, 180 tstat, Falken 512s
Old 05-08-2008, 09:00 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 99 gp gt
AH HA HA HA HA HA HA
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 05-08-2008, 09:15 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 99 gp gt
QTF!!!!!
"Quoted for truth"
Stick with the AC Delco or Denso brands only.
Timeslip 08/12/06
AF Community Guidelines
Old 05-08-2008, 09:30 AM
tblake's Avatar
In God We Trust
Re: 99 gp gt
denso? never heard of them, they make 02 sensors too?
Old 05-08-2008, 09:55 AM
BNaylor's Avatar
Re: 99 gp gt
Japanese up there with NGK as far as quality and performance. A lot of L67 and L36 owners use them. I use the Denso in my GTP and AC Delco in the others. I think the W Body Store still has them available for around $60.00.
Timeslip 08/12/06
Old 05-08-2008, 02:39 PM
tblake's Avatar
In God We Trust
Re: 99 gp gt
Good to know....
