| Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
Help needed with wheel size problem
Hi everyone,
I'm in the process of making the first custom wheel for a future project. The dimensions of the wheel/tire combinations are: Front: 9.0 J x 21 - 245/30 ZR21 Rear: 12.0 J x 21 - 345/25 ZR21 I would need to know what are the exact sizes for 1:24 scale wheels for: a. the outer diameter of the rim b. the outer diameter of the tire Thanks in advance for your help! Ioan |
Re: Help needed with wheel size problem
Hi Ioan,
Something similar to this has apperared in the past IIRC As I recall ZoomZoom posted a very good chart. Try searching for it (I'll also see if I can find it) S
Guideline for happy modeling: Practice on scrap. Always try something new. Less is more. "I have a plan so cunning, you could put a tail on it and call it a weasel" - Edmund Blackadder |
Thanks for the info Steven!
I already looked but only managed to find 2 images posted by hiroboy, and they were only about the rims up to 19 inch. I'll search again, however if you happen to find it please do post a link! Thanks, Ioan |
Consider a thing: our eyes are used to see oversized rims in scale. The R8 Revell rims are correct in scale but they seems very small in diam. and narrowed. A tamiya 19" Enzo rim would be in real life 23 or 24 inches, same for Fujimy: 430 19" are 23 or more inch in 1/1.
When I done the 430 Scuderia rims by rapid prototyping I used (obviously) same (over)-sized Fuji rims (TBH a little bigger), if I must to do a whole scratch rim I would use same Tamiya (or similar manufacturers) dimensions. Just your choice: or "matematically" accurate or "modelling accurate", or better accurate "by eyes", not by ruler.
gio
Wheels have a lip 1/2" to 3/4" high, which adds 1" to 1 1/2" to the diameter of the wheel. So your 21" wheels will essentially look like they are 22" or 22 1/2". If you want to know what that is in 1/24, just divide it by 24- slightly less than an inch.
Outside tire diameter is slightly more obnoxious, but by no means difficult. 245/30 ZR21 means that the tyre is 245mm wide, and the sidewall height is 30% if that. So, multiply 245 x 0.30. Then multiply that by two (because there is sidewall above and below the wheel), divide it by 25.4 to convert to inches, and add that to 21". I got 26 3/4", so in 1/24 that's slightly more than an inch. Math is your friend....
PHOTOBUCKET SUCKS |
Maths were not the problem. I had no idea about how high the lip of a 21" wheel is nor that the tire sidewall height is 30% of it's width! |
BTW, where did you do the rapid prototyping, if I may ask? |
Ioan,
I came up with these: http://www.automotiveforums.com/vbul...06&postcount=9 http://www.automotiveforums.com/vbul...wheel+diameter http://www.automotiveforums.com/vbul...wheel+diameter http://www.automotiveforums.com/vbul...wheel+diameter HTH
Following the link to the rim I done. http://www.automotiveforums.com/vbul...d.php?t=884414
gio
Thanks for your help guys!
Steven you are making miracles with the search system! Gio, thanks for the info, I'll se if I find someone close to where I live otherwise I might get in touch with your contact. Thanks again, Ioan |
Thanks for the tire calculator. Excellent tool!
Does anyone know which kit comes with tires that have an inner diameter of around 25.5 mm? Or maybe a set of aftermarket wheels with this size? I'll try to post a pic of the wheel in a few moments. |
Here's the 3D model of the wheel I want to use. I hope I'll get a 3D printing service to do it for me.
![]() However I'll need the right tires for it, as I'm not to enthusiast about making the model of a tire too. |
25,5 X 24 = 612mm
612mm = 24" (but you should look for a 23", read the above posted links) |
You are right, I got carried away a bit.
21"=533,4mm + 2*flange=35-36mm ________________ = 569,6mm in 1:1 scale and 23.7mm in 1:24 scale I should be looking for tires with inner diameter of 23.5 to 24 mm. If anyone know where to find them, please let me know. Thanks again for your help! Ioan |
