Old 04-20-2008, 03:32 PM
SeanyG's Avatar
SeanyG SeanyG is offline
WIP: Joest Porsche 962C 1/24
My new project is going to be the Joest Porsche 962C from 1989. No reason for this except I love the colour scheme.
This will be another curbside (Booooo!) and therefore the details will be minimal however I will add a few doo-dads in the cockpit but as I'm not opening the doors this time I'm not going overboard with this one. I do have some smart S27 metal wheel and etch set along with a Speedline set too which should help to add a little detail, other than that this is going to be OOB.
This is the beauty (although not quite in the same scheme as the one I'm building) nevertheless I think it looks really stunning.
This is a little more closer to the version I'm building apart from the rear wing...
and so the first observation...
whoever it was at Tamiya who thought having the glass pre-set into the shell was a good idea wants shooting at Dawn . I have read that you can sand these off and then polish them out using compounds and polishing sticks - does this work well and completely remove them?
I have never tried it so any advice greatly appreciated.
Sean
_______________________________
http://www.scalereproductions.co.uk
WIP: Ferrari F40
Old 04-20-2008, 05:39 PM
jaykay640 jaykay640 is offline
Re: WIP: Joest Porsche 962C 1/24
HI Sean
Nice project. Coincidentally i picked up one of these for a good price at a model show this week. Mine will become the 1993 Joest with modified bodywork and rear wing.....one day....hopefully :-)
About the glass pieces....they can be polished. I usually go through the Micromesh pads and then use some acrylic glass polish. But there's another way too, that I'll go whenever i get to my 962s.
Cut out the glass pieces and replace them with vacform ones from the Hiro 962. I got a set for 4€ through "my" Hiro dealer:-)
They'll make painting the body and detailing the headlights easier and should look better too because they are thinner.
One other thing....if you haven't noticed yet: take a closer look at the radiator ducts besides the cockpit. They are way too shallow. You should be able to change that:-)
Looking forward to see what you do with this one:-)
Old 04-20-2008, 06:07 PM
davezilla's Avatar
davezilla davezilla is offline
I built the Dunlop/Shell yellow and red version a couple of years ago and the headlights and windows were part of the body as well. Someone said it used to be a motorized kit, hence the lack of details. I don't know about your kit, but mine had only about 40 parts to it.
btw, I have tried using sanding sticks and compounds for the clear window parts, but it doesn't really do much for me. Although when I use Tamiya wax on them, they appear a lot clearer and thinner. I think it looks better than dipping it in Johnsons/Future, and less messy too.
Completed:
Old 04-20-2008, 10:41 PM
klutz_100's Avatar
Looking forward to following along.
Could be worse you know. It could have also had a die-cast chassis j/k
Old 04-21-2008, 07:22 AM
flhansen's Avatar
flhansen flhansen is offline
Hi
Originally it was a radiocontrolled car in the Tamtech series, that was modified to take a static display underbody. But the problems with the doors and glass were left as they were.
There's also the holes in the side of the body where the catches are for the RC underbody. Needs to be fixed as well.
Flemming
Old 04-21-2008, 07:06 PM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
sweet! nice to see a 962C here in the WIP.
i miss my [FromA] 962C, which brittled and cracked everywhere after i dipped it too long in household thinner (yeah, i was a kid back then).
olly olly oxen free
Old 04-24-2008, 01:51 PM
SeanyG's Avatar
progress...
well a little anyway! I have ordered a further etch set from S27 for the kit and also some new headlight lenses so while I am waiting for those to come I don't to go to far until I know what upgrades are in the set.
However the bits I have done...
the original cockpit divider is solid in the kit but kindly has the holes preformed (why they didnt just have these hollow in the first place is odd)
after a few various sizes of drills in the Dremel...
speaking of which here is the cockpit, plenty of scope for detailing here...
first thing to come out will be the extinguisher and then i will take a look at the bulkhead which looks basic compared to my reference pics.
Back onto the shell and the central wing supports are crude at best, these will be removed and replaced with 2 thin 'V' shaped tubular supports again as per my reference pics.
I also drilled out the exhausts either side of the shell leaving a nice thin looking tubular exhaust end. Had to be carefull here as using too bigger drill would have ruined the moulded exhaust.
Finally, as Jaykay correctly pointed out the vents either side of the cockpit are way to small as can be seen here...
In the picture above you can see where I made the first (very gentle) cuts to the bodywork using my little etchsaw from hasegawa
I remade the centre support from plascard and with a little gentle persuasion pushed the bodywork down somewhat and fixed the support in place with CA glue. I have also made two new sections for the doors and will now let this all set. I will add a little filler and then sand everything smooth and (hopefully) seemlessly!
thats it for now, thanks as always for following and for your comments. More again soon.
Sean
WIP: Ferrari F40
Old 05-01-2008, 04:47 AM
Madish's Avatar
Madish Madish is offline
[url
http://i42.photobucket.com/albums/e331/ohanra/Porsche%20962C/interserie1.jpg[/url]
Damn! That's the place where I live! (Most, Czech Rep)
Good work so far, I'm looking forward to se those PE sets
Old 05-01-2008, 12:10 PM
ejsmith's Avatar
ejsmith ejsmith is offline
I actually managed to pick up a Hasegawa version of this kit from an old toy shop just yesterday so I'll be following your progress closely It's looking good so far though!!
Old 05-30-2008, 02:03 AM
billypee's Avatar
billypee billypee is offline
Send a message via AIM to billypee
Great subject and you have made your usual excellent start Sean.
The modification to the air intakes look spot on. I had a quick look for any other differences I could see between the reference pictures you posted and the moulded body... all I could spot was a missing vertical central support on the air intake directly below the windscreen. Hope that helps.
Bill
On the workbench:
Completed WIPs:
Completed Models Gallery:
Old 07-03-2008, 08:46 AM
SeanyG's Avatar
yes guys, Im still alive - and thanks for your emails - I promise to get onto replying to all those who have emailed me through the forum soon, as well as the triple figures of emails I also have on my pc... urghhh
So I have had nearly two months working away which has been fun but tedious for the last couple of weeks, still no more working away for the rest of the year thankfully.
Since I got back I have made a lot of progress on the Porsche, basically all that is left now is the shell which I am just in the middle of masking and preparing for paint.
I couldnt resist but add a few details to the partial engine/transmission just to add a little interest when looking through the back ofthe car...
As for the cockpit, I removed most of the moulded details and added some hoses and ends to the cyclinders, replacedthe straps on the extinguisher and also added a connector to the end too. I replaced the elctric connects on the box with Perfect parts versions and added cables and heat shrink around the ends. For the seat I used the usual embossing powder and the belts are again from my Modelers set...
Wheels are fabulous and only needed a little polishing and painting here and there, I only added some tyre valves...
the front wheel 'discs' were made up from the etch parts included, I have only to add the tyre markings and then these are done...
FOr the front headlights I removed the moulded surrounds and replaced them with some turned versions and added some glass from the spares box. I also scratched the indicators too as these were missing from the kit...
The dashboard is basically as per the kit, with a little carefull painting and the addition of the a red ignition key (from a S27 seat belt set)...
and finally all in place...
should have some progress on the shell over the next couple of days, I have used the Tamiya supllied masks which came with the kit so hopefully these will be ok.
It's good to be back and for those waiting replies to emails I will be in touch soon, apologies for not getting back to you.
cheers guys!
Sean
WIP: Ferrari F40
Old 07-03-2008, 10:38 AM
SeanyG's Avatar
Bill
Hi again Bill,
thanks for your hints, I added the little centre support to the front duct just as you pointed out.
Sean
WIP: Ferrari F40
Old 07-03-2008, 12:04 PM
godfather23's Avatar
godfather23 godfather23 is offline
Stunning and inspiring! Great job on all the details. Everything looks just right.
Robert
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
Old 07-03-2008, 02:05 PM
All very neat and clean! Looking good!
Old 07-03-2008, 03:25 PM
Madish's Avatar
Yes, he's back! Great work on that kit. I'm looking forward to another update
But there is something you can fix now. The edges of the seatbelts look a bit "teared" so they are white, wash them with blue marker or blue colour
