Old 04-18-2008, 05:03 PM
drob99 drob99 is offline
2002 GP GT jerks from start
hey I got a 2002 Grand Prix GT wit 76K miles and when I'm stopped for about a min or two and then when I press the gas to start driving the car sometimes jerks. What could be my problem?
2002 Pontiac Grand Prix GT 130K miles
Old 04-18-2008, 11:10 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2002 GP GT jerks from start
To start how is the ATF level? Although you only have 76K miles when was the last tranny service? The ATF and screen filter should be replaced NLT 100K miles under normal driving conditions.
What happens when you floor the gas pedal?
Timeslip 08/12/06
AF Community Guidelines
Old 04-18-2008, 11:13 PM
i bought the car almost a year ago. so i dont know when the last tranny service was. Whats ATF?
Old 04-18-2008, 11:20 PM
BNaylor's Avatar
Automatic Transmission Fluid. Dexron-III.
A lot of minor autotransaxle issues are resolved by a basic tranny service so that is the best starting point since the maintenance history is unknown.
Timeslip 08/12/06
Old 04-18-2008, 11:25 PM
well i've been going to valvoline instant oil change since i bought my car and they check everything including the transmission fluid and they say its fine, but they do say i need an entire fuel system cleaning.
Old 04-18-2008, 11:48 PM
BNaylor's Avatar
Rule number one is never trust anyone that works at an oil change shop. They are in business to make money off of people that don't know any better or incapable of do it yourself work. There is no requirement or need to have fuel injector service with your mileage. Even GM doesn't specify it as routine preventive maintenance. Most pump gasoline is detergent based and does a good job of cleaning fuel injectors.
Unless you are getting a SES/CEL (check engine) light either flashing or on steady with stored diagnostic trouble codes (DTCs) the fuel injector service may not resolve your issue. Are you getting a SES/CEL light?
Timeslip 08/12/06
Old 04-19-2008, 05:56 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Also, at 76k, you're probably due for a tune-up including plugs, wires, fuel filter and PCV valve. My 99 had 73k city miles on it when I bought it, and the rear bank of plugs were shot. I had developed a slight off-idle and highway speed passing hestitation, and the tune-up fixed it. She's been running perfect ever since. Try to stick with Ac-Delco plugs and wires if you can find them in your area. Cheapo wires and gimmicky multi-electrode plugs are problematic and a waste of money. Hey Bob, I got thru a tune-up list without bashing Bosch plugs! oops, it slipped,
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 04-30-2008, 01:57 PM
I've had my car scanned and the code came up with p0102
Old 04-30-2008, 02:02 PM
daejuanj daejuanj is offline
Send a message via ICQ to daejuanj Send a message via AIM to daejuanj Send a message via MSN to daejuanj Send a message via Yahoo to daejuanj
http://www.obd-codes.com/p0102
Possible dirty or defective MAF. Hopefully it's dirty, because that part isn't cheap.
- 2002 Pontiac Grand Prix GTP (81K miles)
Magnaflow High-Flow Cat, U-Bend & Resonator delete
Got3800 Race Day!
Old 06-17-2008, 08:26 AM
I took my car in to have the MAF sensor cleaned and that didnt help so It turns out that the MAF sensor was defective. So I took my car in and had the sensor replaced ($190) and its been driving perfect without the jerking when I press on the gas pedal. Plus my MPG is back to normal. Thanks to everyone who helped me out.
Old 06-17-2008, 09:30 AM
lil_nages22 lil_nages22 is offline
Where did you buy your MAF sensor from?
I have bought one from zzp, saved a few bucks, but it was just as bad as the one I had on my car before.
Old 06-17-2008, 09:55 AM
I took my car to my mechanic that I had been dealing with for about 3 or 4 years. So I dont know what brand name he used.
