Old 04-04-2008, 01:05 AM
latestgood latestgood is offline
HELP! Something with my throttle?!?!
Hello,
I have a 2002 Saturn SL2 (82,000 miles) Couple weeks ago, I've been hearing mteal clunking noise when I step on the gas. After much observation, this is what I happens:
- The clunking noise appears when I step on the gas
- It usually happens after driving my car for 3 hours
- The clunking noise goes on for an hour or two and disappears
- The clunking noise appears around 5-40MPH
- When clunking noise appears, the clunking noise increases as I step on the gas
- The clunking noise dissappears when car acclerates over 40-50MPH
- There is no clunking noise when I step on the gas in netural
- Recently, as clunking noise appeared as I pushed the gas, my rpm rapidly moved up and down from 1,800 - 2,000RPM
From this observation, could it be my throttle body or something else?
Old 04-05-2008, 03:58 PM
maxwedge maxwedge is offline
A990 racer
Re: HELP! Something with my throttle?!?!
Realistically someone knowledgeable has to drive this to really figure out what's what.
Old 04-07-2008, 01:55 AM
72chevelleOhio 72chevelleOhio is offline
I agree with Max, however, I am going to guess its a transmission problem. Just 'cuz.
Old 04-07-2008, 02:22 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
It's confubulator.
Old 04-07-2008, 04:36 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
This is one of those situations where describing noises on the internet fail the magic prize. You might have to find someone to actually drive it.
From your description, the list could be huge: motor mounts, belt-driven accessory, transmission, CV joints, differential... who knows?
It does sound like a transmission issue if you're getting widely varying RPMs, but you didn't mention if its a manual or automatic so its tough to guess.
Dragging people kicking and screaming into the enlightenment.
