Go Back   Automotive Forums Car Chat > Buick > Regal
Old 04-03-2008, 08:50 PM
eccs19 eccs19 is offline
99 Regal Front Struts
I have been reading, and I see that the front's are easy to change on the older Regals (early 90's). Are they just as easy on the newer ones like mine, or more of a chore?
Old 04-03-2008, 11:18 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 99 Regal Front Struts
It depends on what the meaning of easy is. Other than having to remove the complete strut assembly and then use a strut coil spring compressor to replace the strut not too bad of a DIY job. A wheel alignment should be performed afterwards.
Also, depending on your mileage you should consider replacing the upper strut mount and load bearing.
Timeslip 08/12/06
AF Community Guidelines
Old 04-04-2008, 06:27 AM
Thanks for the info. I don't think I'm needing it yet, but was mostly curious.
