Old 04-03-2008, 05:43 PM
jayjack jayjack is offline
2 stroke engine + forced indiction?
is it possible to add forced induction to a two stroke engine? i mean if you want to add power to an old bike or something could you find (or i guess make) a supercharger and bolt it on with our ruining the engine?
Old 04-03-2008, 07:42 PM
jcsaleen's Avatar
jcsaleen jcsaleen is offline
Re: 2 stroke engine + forced indiction?
No-smoke two-stroke promises power with economy
By John Simister
31st March 2008
British engineering research company Ricardo is developing a new petrol engine which combines two-stroke and four-stroke operating cycles. Past two-strokes have compressed the fuel and air mixture in the crankcase, which precludes the use of an oil sump so oil has to be delivered with the fuel, causing polluting oil smoke. But this new engine, dubbed 2/4SIGHT, uses normal overhead valves and a normal oil supply.
So how can it be both a two-stroke and a four-stroke? By altering the valve timing and ignition timing radically. The valves are electro-hydraulically actuated so there are no camshafts. This means that at certain speeds and loads, the valves can open during every piston stroke instead of every other stroke, and direct injection means the air swirl and flame front can be controlled to let the downward-moving piston suck in intake air even while the power stroke is finishing. Forced induction, using both a supercharger and a turbocharger, ensures sufficient intake air enters the cylinder.
In two-stroke mode the engine delivers remarkable torque: a one-litre verion would manage about 170lb ft at 2500rpm. This means, for example, that a 2.0-litre V6 2/4SIGHT engine would match a conventional 3.5-litre V6 when worked hard while proving much more economical when cruising in four-stroke mode. Ricardo estimates a 27 per cent improvement in economy and CO2 output. The control system, co-developed with Denso, also promises 'seamless' switching between the two modes.
Currently the engine exists as a three-cylinder testbed, but the project is backed by a 'consortium of automtove partners'. We've seen revoltionary two-stroke engines before – Ford came close to productionising the Australian Orbital unit – but with today's computing power to control it, and today's need for smaller, lighter, more frugal engines, the Ricardo 2/4SIGHT seems like a promising idea.
>>> www.evo.co.uk/news/evonews/219681/ricardos_special_two_stroke.html
"Driving a Mazda RX7 on the track for the first time was very cool ? this is a production car that most
resembles the movement of a formula car in my experience so far.
" ~ Igor
Old 04-04-2008, 01:40 AM
UncleBob UncleBob is offline
AF -Advisor
there's hundreds of banshee's, to name just one application, that are 2 stroke turbo'd
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 04-04-2008, 04:51 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
a 2-stroke with a separate crankcase is nothing new. Detroit diesels back to the early 70s were 2-stroke with a blower.
traditional 2-strokes develop airflow because the dropping piston compresses the air/fuel in the crankcase, forcing it into the port. 2-strokes with a crankcase oiling system require forced induction, otherwise they wouldn't start.
Adding forced induction to a 2-stroke is a delicate thing. Since there is a great deal of exhaust/intake overlap, forced induction is a bit of a losing battle. When the intake and exhaust ports are both uncovered you run the risk of simply blowing all the pressure out the exhaust. Since you don't have valves and cam timing events to control when pressure enters the cylinder, you can't control where it goes.
I'd like to see some data on adding boost to a 2-stroke since I've never actually witnessed one (other than a detroit diesel)
Dragging people kicking and screaming into the enlightenment.
