Old 03-30-2008, 06:31 PM
skippygozoom skippygozoom is offline
Question '89 S-15 Jimmy Steering???
I just bought an '89 Gmc Jimmy, and it runs and drives pretty well.Only real problem I have noticed is that the steering is very loose. I would say there is about 1 1/2 to 2 inches of play in the steering wheel both ways. It makes driving very hard. I read that you can tighten' the steering box and that that might help. I was hoping that someone might be able to give me a general idea of how this is done. Is it the bolt right on the top front side of the steering box? It is the adjustable type. Well any help would be awsome. Thanks for reading..
Old 03-30-2008, 06:46 PM
Khill Khill is offline
Re: '89 S-15 Jimmy Steering???
as in you move the wheel 2 inches until you get a response or you only have a wheel rotation of 4 inches from full left to full right? I'm a little slow today....
Old 03-30-2008, 07:44 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
You can tighten the box, but they're pretty complicated inside. It will change the lock-to-lock points and it should be done with a good bit of caution.
There is a nut and lock on top of the box. In this photo its the nut in the center of the aluminum cap on the bottom. You use that to adjust preload on the gear in there. I've never tried it... yet, but I need to learn so I can do the same thing on one of my cars. You can't go too far or it will bind.
Dragging people kicking and screaming into the enlightenment.
Old 03-31-2008, 01:53 AM
72chevelleOhio 72chevelleOhio is offline
^Good info on the gear box.
Originally Posted by skippygozoom
I just bought an '89 Gmc Jimmy, .Only real problem I have noticed is that the steering is very loose. ..
Did you check the front end for worn components yet? That would kinda be important to check and mention in your post...
The "pre-owned" ones that I've gotten always have a bad idler arm. I don't know if they forget to grease them or they are a bad part from the beginning.
Old 03-31-2008, 03:02 PM
J-Ri's Avatar
J-Ri J-Ri is offline
I think all the idler arms are bad. I've seen some that are still new looking that are loose.
If the steering box is loose, you can tighten the adjustment Curtis mentioned. There is a stud in the center with a hex/torx cut in the end, and a nut around it. I think you hold one and turn the other, but I don't remember which. I did it on my '86 Silverado 4-5 years ago and it was tighter for a few months, but got just as loose again so I left it alone.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
