Old 03-30-2008, 12:22 PM
Blue Bowtie's Avatar
Registered Offender
-=<Read This Before Posting Anything>=-
Please use the Problem Diagnosis forum for any and all threads requesting technical assistance or advice. Unless you are posting about a sound system, appearance modifications, or non-technical information, almost all threads should be posted in the Problem Diagnosis forum.
A look at the Cavalier forum should reveal just how many threads are routinely moved as a result of posting in the incorrect forum. If you would like the fastest replies and most appropriate attention, post in the proper forum.
Thank you for your help.
The Following User Says Thank You to Blue Bowtie For This Useful Post:
ole hornet driver (03-25-2013)
Old 09-29-2009, 06:56 PM
kelly vicary kelly vicary is offline
Re: -=<Read This Before Posting Anything>=-
hi i am new here and i have a2001 chevy caviler with clutch problems the pedal goes down till about two inches form the floor and then it is hard like a stone i have replaced the clutch master cylinder and that worked for about four days can any one give me advice on what is wrong orif you seen this before and how did you fix it
Old 09-29-2009, 07:17 PM
rhandwor rhandwor is offline
I would check that you bleed the system properly. Then check out the slave cylinder.
Old 02-08-2010, 12:37 PM
OSCAR790608 OSCAR790608 is offline
I have a 2000 chevy cavalier that won't stay running? You have to pump the gas pedal while turning the ignition to get it to start up. Once it is started up you have to leave your foot on the gas to keep it running or the engine dies?
Old 09-27-2011, 08:40 PM
dada no 23 dada no 23 is offline
hey i got a 98 cavalier i need to change wheel lock cylinder but dont have a key....any suggestions? i can get car operating but need to change cylinder and cant figure out how to get it out
