Old 02-28-2003, 01:24 PM
hogtrash hogtrash is offline
Radio problem
:smoker2: :smoker2:
96 camaro. Anyone have an idea why I would be getting nothing from my radio? No lights no sound no nothing? I checked the fuses,. they're good. Any ideas?
Old 03-02-2003, 03:18 PM
Raceghost's Avatar
Raceghost Raceghost is offline
Send a message via MSN to Raceghost
DId you check all the fuses...
ther is fuses of course in the dash, and fuses behind the radio, nad fuses in the engine bay. Just a thought. It also might be that switch the is in the door that shuts the radio off when you open the door. Just some possibilities.
Raceghost
Rocket powered now...
88 Jeep Cherokee Pioneer (Rebuilt).
00 Honda RC51 (...whispers of super bad!)
04 Mitsubishi Evolution VIII (Finally!)
Lead, Follow, or get the f... out the way
Old 03-05-2003, 12:46 PM
Radio problem
:smoker2:
I'm going blind.. I've been searching the net for a clue on this problem but it's not out there.. My Haynes manual doesn't help...Does ANYONE have a clue of what's going on? Other then the inside and relay fuses in the engine, are there any others? Not sure if I mentioned this but my power windows don't work either.. Both went out at the same time... help me or put me out of my misery.. I'm like a dog with a bone when something is wrong.. I can't stop trying to fix it until it's fixed.. yep obsessive behavior problem.
Old 05-27-2003, 07:28 PM
Raceghost's Avatar
I have now joined you....
I am now in the hunt for this solution as well. My stereo will now not com on, but the amp remains on and is inducing alternator noise. Along with the fact that I can here my power windows through my dash...YES, ISAID my DASH. It sounds like a relay is tgoing out in my steering column, or behind the dash. When I press the triger on the drivers side window, a annoying noise comes from behind the dash. Any ways, If you have found a solution please reply.
Raceghost
Old 05-28-2003, 10:25 AM
radio problem
:smoker2: :smoker2:
Hi Race ghost. I finally took my car into the chevy dealer after I had changed out all the fuses and researched and researched this problem. I had it down to a couple of possibilities, but I didn't want to hit and miss becasue the parts are not returnable. The first one I thought of was the Body Control Module. cost was 120.00 the other could have been the ecm or who knows what .. point is I could have put a lot of money into it before I figured it out so I wimped out and took it to the dealer. 5 days and 609.00 later they had it fixed by replacing the body control module. I don't think this is your problem by your description.
F-250 radio problems...Need help farmboy401 F Series 0 05-10-2010 07:10 PM
Radio problems/ Rt rear window won't move/ Lights dim when shifted in Reverse Baxoid Grand Prix 2 01-03-2010 06:50 PM
please help monsoon radio problem friend cut harness into back of radio 94cordvtec Grand AM 1 11-12-2009 10:07 PM
2000 Cabrio Does not initially start, Radio Safe, Clock 1200 ptb123 Cabrio 0 04-11-2009 05:10 PM
DRL problem plus radio problem PyroTech General Discussions 0 03-16-2005 05:07 AM
