Old 02-28-2003, 12:55 PM
VelocityCivic91's Avatar
VelocityCivic91 VelocityCivic91 is offline
Send a message via AIM to VelocityCivic91
B16a1 owners... I NEED YOR HELP!!
Ok, this is my problem... This morning I walk to my car, and turn it on. I notice that as soon as I turn the car on that I have a check engine light on. Last night when I parked my car after I got off of work, I did not have the light on, and the car was running fine. So, I though to myself that I will fix it later. Well, I try driving out my driveway, and the car spits and sputters when I step on the gas pedal and almost stalls out. If you ease on to the gas pedal, it will slowly accelerate, but it will only go to 3,000 RPM and no firthe and the car starts to make like a back fireing noise. My dad is a mechanic, and he says that he thinks I have a fuel pressure problem. My dad says that if it is a fuel pressure problem, then it would not throw a check engine light. He also said that I should replace the fuel filter before going any firther. I checked the cap and rotor and they are fine, because I thought it could be a spark problem, but it does not seem like it. If anyone here has had the same problem with there B16a1, and has fixed it, or knows what the problem is, PLEASE let me know a.s.a.p. I have heard form some people a while ago that JDM motors throw different signals in there check engine lights then the USDM engines. If anyone knows a websites that have JDM engine codes, please let me know. Thanx a lot for your help.
WARNING: Surgeon General says it's O.K. to smoke V-8's.
*** Looking for a B&M fuel pressure regulator and guadge***
Old 02-28-2003, 01:17 PM
dfarres's Avatar
dfarres dfarres is offline
Send a message via Yahoo to dfarres
I'm no expert but ur problem sounds just like the problem i had with my mercedes.....
i parked it friday after work... got in it monday morning & it started weird then i couldnt get it to rev over 2500 rpm. I drove it 20mph to a shop & $100 later they told me that I or the person b4 me had got some gas with water in it & it had slowly rusted out my FI system internally & was gonna cost 2 or 3 thousand to fix...
Needless to say i sold it to a junk dealer for $950 so he could swap parts from it.
Try replacing the Fuel Filter & go from there.
1993 Civic Coupe EX
1997 Chevy Suburban LT
“It's all fun and games - Until someone loses an eye"
Old 02-28-2003, 01:53 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
sounds like u need a whole new distributor. Mine did that and i had to replace the distributor. Check the codes on ur ecu.
Old 02-28-2003, 03:57 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Crack in the Dizzy cap would be the first suspect, closely followed by a stuffed dizzy. Good luck on sorting it
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 03-01-2003, 10:53 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
my dizzy died like that too, id check that first.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 03-02-2003, 11:20 AM
I highly doubt it to be my distributor. I checked the cap and rotor and they are fine, I replaced them about a month ago, so they got to be fine. I am getting spark, and the car is turning over. I replaced the fuel filter, and it is still NOT working. My dad says that the fuel pump is not getting power to it. We tested the main relay and the main relay is fine, so that is not it. I checked the fuses, and all fuses are fine. The only thing that me and my dad think that it messing up would be the ECU. There is a little red light that is ON inside that ECU, but does not flash. Does that fuel system go through the ECU???? Does anyone know where that fuel pump relay or a fuse that goes to the fuel pump located???? Does anyone know where there ia a website that has the "Check Engine" light codes for my JDM motor? I heard that US motors have different codes that flash than the JDM motors. Any help would be GREATLY APPERECIATTED. Thanx.
Old 03-02-2003, 12:29 PM
mellowboy's Avatar
Just because u replaced the cap and rotor doesn't mean it solved the problem. I replaced the coil and it started up and everything. A week later it died. SO what i did is that i replaced a whole new distributor.
Code System
Code 1 (1 flash) Oxygen content
Code 3 or 5 Manifold absolute pressure
Code 4 (4 flashes) Crank angle sensor
Code 6 (6 flashes) Coolant temperature
Code 7 (7 flashes) Throttle angle
Code 8 (8 flashes) TDC position (top dead center) timing
Code 9 (9 flashes) No. 1 cylinder position (1.6L)
Code 10 (10 flashes) Intake air temperature
Code 12(12 flashes) No code 11 don't know why. Exhaust gas recirculation system
Code 13 (13 flashes) Atmospheric pressure
Code 14 (14 flashes) Electronic air control (EACV)
Code 15 (15 flashes) Ignition output signal
Code 16 (16 flashes) Fuel injector
Code 17 (17flashes) Vehicle speed sensor
Code 19 (19 flashes) No code 18 for some reason Lock up control solenoid valve
Code 20 (20 flashes) Electric Load
Old 03-02-2003, 03:34 PM
Mellow, are those codes for a JDM B16a1 motor? Plus, my little red light inside the ECU DOES NOT FLASH at all, it just stays on. I also replaced the ignition coil the same time I replaced the cap and rotor.
When I started this thread, the car would start, but idle funny. The next day the car just wont start now... thats why I am saying that it is the fuel pump. Again, I am not getting any power to the fuel pump. My dad and I took off one of the lines running to the fuel pump, and put it in a milk jug. Then, I turned the car to the "ON" position, and my dad said that no fuel gushes out, like it should. SO, I know it has something to do with the fuel pump, fuel pump relay, or maybe something in the ECU. I am sooooo stumped.
Old 03-02-2003, 03:40 PM
mellowboy's Avatar
Yeh those codes are the same as any obd0. If you think its the fuel pump try replacing it. About ur ecu i'm thinkin that its normal. Not sure about that.
Old 03-02-2003, 06:07 PM
91zc 91zc is offline
A solid red light on the ecu means it is cooked. The ecu should blink a couple times on startup and when there is an error code. If the ecu is working properly it will only blink on startup while the CEL is on. Sounds to me like it is time for a new ecu. See if you can borrow a good ecu. It doesn't hae to be a b16 ecu just one that runs mpfi ie 88-91 civic/crx si ecu or a zc ecu or even an 89 integra ecu. Just find one that will start the car and then that will tell you for certain if the ecu is dead.
91 civic 4dr
b16a
14.8@94
Old 03-02-2003, 08:25 PM
91ZC... I think that your right, the ECU is done. My dad and I ran a jumper wire to make the fuel pump get power. The pump is working now, so the question about the fuel pump not working is out. The pump is good.
Now, when all of this started to happen to the car, it was rining outside. And when it did not run properly, I pulled my car into the garage and my dad and I proceded to look at it. One of the very first things we saw was water on the ECU, and the red light on.
My dad and I finally narrowed it down to the ECU, and he said that it is probly bad. Right after he said that I told him I was going to get on the computer and check to see if anyone has said anything about my situation. Sure enough, you said the ECU might be cooked, and I think it is. At least my dad thinks so, and you do. I found out I have a PWO ECU. Now when I get a new ECU, should I get a PWO or a PR3???? I heard that PR3 ECU's will work sice my car is OBD0.
Thank you 91ZC and everyone that has helped me out. Everyones advice has helped me out sooooooo much. I will let you guys know if it is the ECU for sure (which my dad and I think it is). Again, thank you guys for your input. You guys ROCK! :sun:
Old 03-02-2003, 08:40 PM
I would get a PR3 if possible. It is easier to get it reprogrammed if you are thinking of doing that. Yeah, water and the ecu will not mix especially if somehow water got inside the ecu box. Good Luck getting the problem fixed.
91 civic 4dr
b16a
14.8@94
another try....280 owners need some help! redneckshen 240Z | 260Z| 280Z | 300ZX (Past Z Cars) 4 06-27-2005 12:40 AM
Mazda B2200 Owners Need your help! Kaseobeer B-Series/Bravo/Bounty/Drifter 2 09-10-2004 11:32 AM
New 944 owner, need your help! Jade7395 924/944/968 3 11-16-2003 05:19 PM
2g integra owners need your help!!! crvtec_integ Integra 1 02-18-2002 10:12 AM
T4 owners, Need some help please GoodJuan General 7 10-29-2001 09:26 PM
