Go Back   Automotive Forums Car Chat > Honda > Integra
Old 02-28-2003, 09:59 AM
purespeed187 purespeed187 is offline
what to do after intake header exhaust???
hey i just bought an injen 3"intake got the aem bypass valve too i also bought a DC stainless 4-2-1 header and a apexi ws exhaust my question is what should i do next??? i think ill get skunk stage 1 cams but im not sure??? is there anything else i should look at getting first?
Integra GS-R
Injen 3" cold air intake
apexi WS exhaust
Old 02-28-2003, 03:49 PM
GSR GSR is offline
Send a message via AIM to GSR
stage 1 is a waste of money
looking for a 95+ 240sx in/near D F Dub area
Old 03-02-2003, 08:47 AM
CrazyFukr2k3 CrazyFukr2k3 is offline
Send a message via ICQ to CrazyFukr2k3
get stage 2 camshafts, dont get stage 3 or higher tho thats for hardcore street racers and it messes up your idle bad (idle at 2000 rpm when the cars warm)
you could get an upgraded ECU, like $150 for it plus professional installation and that'll do like 10 horsepower and might increase mileage
you could get iridium spark plugs and performance spark plug wires for about $80 for 4 plugs and the wires
you could get MSD ignition. at high rpms your spark plugs start to do worse because theres not enough power.
you could get a high flow catalytic convertor, or a straight pipe if your car is new enough that it doesnt need to be smogged (or put the straight pipe on and swap in the stock cat for smog tests)
Never judge someone until you walk a mile in their shoes, then you're a mile away from someone you hate, and you have their shoes.
Old 03-02-2003, 11:49 AM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Get a Skunk 2 intake manifold.
Old 03-02-2003, 05:34 PM
GSR GSR is offline
chip=not needed for your curent mods
iridium plugs=maybe a 1hp gain, not worth the $80
msd=your stock ignition can handle +250hp @ stock gap, so again not needed
test pipe/high flow is fine, nitrous would be better
Old 03-02-2003, 07:52 PM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
high flow cat...i need one...
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 03-02-2003, 08:06 PM
i herad stage 2 cause bad idle as well and i heard the stage skunk2 intake manifold just takes all of you low and mid range power and converts it to high end i dont know about you but i dont drive my car at 8000 rpm down the street. im thinkn nitrous will be next but just need to do more research i dont want to blow up my car. Gsr what did you have in your car before u put the nitous in???
Integra GS-R
apexi WS exhaust
Old 03-03-2003, 12:46 PM
GSR GSR is offline
daily driving doesnt take advantage of the dual runner design either...I shift at 3k every gear, the gsr manifold is designed to outflow during mid-range so really youre not losing much with the skunk2. racing requires more top-end and daily driving is all low-end. I dont know what honda was thinking when they designed it
with a 65 shot you dont need anything but an a/f gauge to monitor your mixture (cockpit nitrous gauge optional). You can buy it for $45 and install yourself, 3-wires. if you ever see the gauge read orange it would be a good idea to get an inline pump.
also before you spray be sure your car is running its best. new fuel filter, plugs (ngk is best, 6 or 7 heatrange are both fine), distribuitor cap & rotor.
Old 03-03-2003, 04:28 PM
dont i have to retard the timing in my car ????
Integra GS-R
apexi WS exhaust
Old 03-18-2003, 07:49 PM
redmanjd redmanjd is offline
i noticed a big gain in a lightened flywheel. it revs and falls very quick
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
intake headers exhaust pinkfloyddreamer Integra 4 07-29-2004 02:17 PM
What first? intake or exhaust? perna00 Eclipse 2000+ 15 07-15-2004 07:49 PM
97 gsx w/16g vs. honda s2000 with intake, headers, exhaust newGSXguy Off-Topic 101 05-06-2004 08:47 PM
Getting Intake/Header/Exhaust...where to start? Kinked210 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 01-15-2004 04:06 PM
