Go Back   Automotive Forums Car Chat > Racing > Non Specific
Old 03-28-2008, 09:09 AM
BeZerK2112's Avatar
BeZerK2112 BeZerK2112 is offline
380HP Isn't Enough...
Spring time Mods!
Seams dead... Thought I would see what people are planing on doing to their cars this spring/summer.
Maxima
I've got 2 things I am planning on. I'm rebuilding my front end. New Control arms, bushings, ball joints, tie rod ends... Needed to replace all the bushings so why not everything. I'm considering doing the wheel barings, but dont have any signs of problems. I'll pull them out and look at them, maby regrease them if need be. The second thing is replacing the fuel filter, got the 300ZX fuel filter for the maxima.
Datsun
Needs a brake overhaul. I have to take everything apart to see where I'm at and what I need. I have a leak somewhere in my rear brake lines, only my front brakes work.
Other then that, if I have any extra money I'll be sure to try to put it into the maxima, or buy a macbook pro. I have a feeling i am in the need of a new CAT. If thats the case, I would want a full 3" out and bla bla bla,money money money...Car sounds great.
Mid April, Poly and I are doing a lot of fun stuff to his cars. Taking about 4 days and going to Utah.
WHAT KEEP IT STOCK! Well that takes the fun out of it.
[center]
99 Maxima - View the Project at CarDomain
Old 03-28-2008, 04:11 PM
CassiesMan's Avatar
CassiesMan CassiesMan is offline
AF Vendor
Send a message via AIM to CassiesMan
Re: Spring time Mods!
Finish the turboback, trying out one last new BPV, Cobb Accessport and springs, and some general goodies (silicone boost tubes, paint the intercooler cover, NGK 1 step colder, shifter bushings), start prepping for law school. Also, if I find myself a surprising sum of money, get the stock K04 ported/polished with a new wheel.
2006 Redline Red Nissan 350Z Base
K&N|Falken
I am just that JDM tight, yo.
Old 03-28-2008, 04:24 PM
TorchedStealth's Avatar
TorchedStealth TorchedStealth is offline
Send a message via MSN to TorchedStealth
May not be spring...but more so summer mod plans
Im planning on getting GM stage 2 kit and an ingalls torque damper. Later on hopefully a 2.9 inch pulley and a cobra heat exchanger
2005 Saturn Ion Redline - Injector Dynamics 1000cc Injectors|E85|Harrop TVS1320 Blower|2.9" pulley|3" Intake|Vibrant Header and catless Downpipe|Hahn 3" catback|N2MB Wot Box w/2-step and no-lift shift|Cobra Heat Exchanger|Hurst STS|Ottp Stage 1 trans mounts|AEM EUGO Wideband|Aeroforce Interceptor|HPTuners (self tuned)|Mop Top Pros Carbon Fiber badges|B&G Springs
Old 03-28-2008, 04:39 PM
AMGalltheway's Avatar
AMGalltheway AMGalltheway is offline
First I plan on getting the thing back on the road(vacuum pump bearings disintegrated and are in the oil pan thankfully they didnt get into the oil pan). After I get a better paying job i hope to save up for a manual tranny or a Sportline suspension kit from AMG.
1987 Mercedes Benz 190D turbodiesel
-5 speed transmission swap
Old 03-28-2008, 06:54 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
nothing planned for the car, all my money's going into the ninja. new front(-1) and rear sprocket(+2), new chain, new tail light w/integrated blinkers, and a jardine slip on exhaust. should run me about $1000.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 03-28-2008, 11:09 PM
Sleepr awd's Avatar
Sleepr awd Sleepr awd is offline
Send a message via AIM to Sleepr awd Send a message via Yahoo to Sleepr awd
just trying to get the mean green working.
Don't act like you don't love it.
503/2000
Old 03-28-2008, 11:27 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
<Thinks about it, brain implodes........>
Anyhow, needless to say, a shit load. I have an entire room of parts that need to go on and more will be on the way before the end of modding season. Well, here's a list of crap for both cars.
GTC:
  • Install suspension which includes dampers, bars, bushings, mounts, springs, ball joints, wheel bearings, tie rod ends, steering pump, and lines.
  • Install brake pads, SS lines, rotors, fluid flush, and paint calipers black.
  • Swap the shit brown interior to gray.
  • Install vacuum block and new vacuum lines.
  • Polish lettering and fins on valve cover and intake manifold.
  • Install 3" swing valve and down pipe.
  • Install ignition.
  • Replace valve cover gasket.
  • Install new gauges.
  • Fix rear window seal.
  • Battery relocation.
  • Stereo install.
  • Change ugly rubber boot for leather.
  • Change all fluids with RP.
  • Paint all black trim.
I'm also debating between doing the transmission work or the body work this summer. I'm sure there's something in that damn room I'm forgetting.
Stealth:
  • Change plugs & wires.
  • Change fuel filter.
  • Polish lettering and fins on my new white powdercoated valve cover and intake manifold and install.
  • Pull the BCS plug.
  • Pull the ESC computer and load it in a skeet shooter. DONE!!!
  • Replace the clock-spring.
  • Subwoofer install.
  • Change wheels. IN PROGRESS!!!
  • Gauge install.
  • Change dash vents.
  • Change steering wheel.
  • Change door panels.
  • Change seats.
  • Install pedals.
  • Pull ABS fuse.
  • Fix bolt in rear wing. THIS WEEKEND.
  • Fix leak in AC and recharge.
  • Change reverse switch.
  • Change washer fluid reservoir. THIS WEEKEND.
  • Change fog light bulbs.
  • Change air deflector.
  • New y-pipe.
  • Install pre-cat eliminators.
I'm thinking about doing the brakes as well with new rotors and SS flex lines. I also want to powder coat the calipers but I don't know what color. The new wheels will be black with a polished lip so I'm thinking black, white, or red. Not sure....
Old 03-29-2008, 03:30 AM
GForce957's Avatar
GForce957 GForce957 is offline
Fix Bumper and add pipe to make a true CAI
Oil change RP
Catback Exhaust- thinking Magnaflow, possibly others but 89% sure
Tires- 265 back, 245 front, most probably GForce KDW's
Gears if I have enough time and money- 3.73 or 4.10's
Old 03-29-2008, 10:08 AM
CivRacer95's Avatar
CivRacer95 CivRacer95 is offline
srs biznis
Send a message via AIM to CivRacer95
Hrm...spring time mods...lemme think...
BUY A NEW FRIGGIN CAR!!
(maybe)
AF Guidelines. Read and play nicely :
Just Click Here!
Old 03-29-2008, 02:56 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Buy a new car. And assuming another rod does not go flying through my motor and breaking out of the bottom on my bike agian, I will not have to do anything mechanical to it. However, I did just buy some new leathers, hand grips, factory effex seat cover and a few other misc. things.
Old 03-29-2008, 03:05 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
Ehh... who knows with me... I flip flop so much on what I want.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 03-30-2008, 11:49 AM
CivRacer95's Avatar
srs biznis
You sound like a chick...
Just Click Here!
Old 03-30-2008, 12:14 PM
-The Stig-'s Avatar
On Fire!
At least I have good taste...
Old 03-30-2008, 02:01 PM
MZR_47's Avatar
MZR_47 MZR_47 is offline
Send a message via MSN to MZR_47
You should consider yourself lucky that the rod didnt continue its path and exit through your leg, taking god knows what with it.
Plans = Buy Mazdaspeed 3 in June. CAI, CDFP, SB-E will follow almost immediately after I get it. Not much after that, atleast until i build up some bank to get the FMIC or boost controller.
MOAR BOOST
Silencer Delete | SPT Catback | Megan Racing DP | TEIN Flex Coilovers | Front and Rear Sway Bars | DBA Rotors | TurboXS UTEC | 18 psi
Old 03-31-2008, 01:27 PM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
currently its:
fix rust on drivers door
fix rust on trunk
fix rust starting in passenger door
install header and midpipe
replace rear o2 sensor
get the front bumper repainted
get the rear bumper repainted
get the right side of the car repainted
mount the cd deck in a different location
after all that, hopefully sell the sentra, as im looking for a 94-95 clean miata clean of rust and paint damage, with the Limited slip.
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
