Old 03-24-2008, 01:02 AM
oinkinstein oinkinstein is offline
Exhaust Cutouts
i want to put cutouts on a vehicle with measly 1.75" pipes (and i dont feel like changing it to 2.25) but anyway all the cutouts i see online are for 2.25 and up.
can i use a step clamp?
or is there something i can use to easily adapt the 1.75 to a 2.25 cutout?
thanks
if you do find or have heard of a cutout that specifically fits 1.75" pipes (doubt it) please give me the link
Old 03-24-2008, 02:23 AM
KiwiBacon KiwiBacon is offline
Re: Exhaust Cutouts
I have no idea what you mean by a cutout. But most exhaust shops can flare exhaust pipes out, from 1.75-2.25" isn't a problem.
Old 03-24-2008, 04:06 AM
72chevelleOhio 72chevelleOhio is offline
Re: Exhaust Cutouts
Here's a 2 inch cut out...
http://store.summitracing.com/partde...5&autoview=sku
You can buy the adapters at most auto parts stores....
If I dare ask......what for???
Old 03-24-2008, 05:30 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Exhaust Cutouts
the reason cutouts aren't sold for smaller exhausts is because they aren't needed. If you have a car that "needs" cutouts, chances are you've exceeded the HP capacity of a larger exhaust.
If you want a cutout, check JCwhitney. If you NEED a cutout, check Summit Racing.
Dragging people kicking and screaming into the enlightenment.
Old 03-24-2008, 09:47 PM
Re: Exhaust Cutouts
oh it's definetly not for horses i've gotten what i can out of the truck with a cam,intake and head porting, i just want it to be insanly loud, i used to run straight pipes on it but got too many tickets, so E cutouts will be perfect
thanks for the advice guys
Old 03-26-2008, 03:32 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Exhaust Cutouts
Summit sells a cable controlled exhaust valve. Basically, you just install a "T" in the exhaust before the muffler and install the valve on the "T". Closed, it's quiet, open you have straight pipes.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-28-2008, 11:39 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: Exhaust Cutouts
Traditionally, cutouts were an old hotrodder thing. You would divert the exhaust through the rocker panel mounted lakepipes. Also the ones that let out under the rearmost edge of the front fenderwells are cool too.
If you let the gases out under the vehicle, you put yourself and anyone in the car in danger.
Bob
Old 04-03-2008, 07:53 PM
jcsaleen's Avatar
jcsaleen jcsaleen is offline
Re: Exhaust Cutouts
Cut outs are for High displacement and forced inducted cars that don't hurt from loss of back pressure. If your running a 1.75 pipe you most likely are running a 4 or a small 6 cylinder... You don't need a cut out thats just $ out the window and maybe hp too...
"Driving a Mazda RX7 on the track for the first time was very cool ? this is a production car that most
resembles the movement of a formula car in my experience so far.
" ~ Igor
