Go Back   Automotive Forums Car Chat > Buick > Regal
Old 03-23-2008, 07:42 AM
eccs19 eccs19 is offline
99 Regal GS - Couple minor questions
I've got a 99 Regal GS. (Love the car)
I need to change my termostat. I've changed lots of thermostats, but never one where the system needs to be bled. Any tips / tricks? Where is the bleeder for this?
One other issue that happens once in a blue moon. With performance shift OFF, sometimes if under 3/4 throttle, the shift from (I'm going from memory here) 2nd to 3rd gives one heck of a bang. Almost enough to break the tires loose. Should I worry, or not, as it is infrequent.
Thanks!
Old 03-23-2008, 08:40 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 99 Regal GS - Couple minor questions
Welcome to AF.
The bleeder is located on the thermostat housing. Just follow the upper radiator hose towards the engine.
On the performance shift off issue what is your mileage and is the bang more like a hard or harsh shift?
Timeslip 08/12/06
AF Community Guidelines
Old 03-23-2008, 09:12 AM
Originally Posted by BNaylor
Welcome to AF.
Thanks for the bleeder info. Does this car require special coolant when topping it back up?
Mileage is just under 200,000 km. When I first got the car, I took it to the local tranny shop, and they were impressed with how clean the fluid was. It is more like a hard shift, but you can hear it, hence the bang.
Old 03-23-2008, 09:30 AM
BNaylor's Avatar
It uses Dex-cool coolant. If this is being currently used then stick with the Dex-cool. It is orange in color. Do not mix Dex-cool with other coolants to include extended life on the market or you will get a sludge build-up. The other option if status of coolant is unknown is to flush the cooling system and get rid of the old Dex-cool and use the regular extended life coolants like the Prestone Extended Life.
The shifting sounds abnormal to me. My Regal GS doesn't do it or at least no bang when it shifts from 2-3. When you get a chance get it scanned with a trans capable scanner and see if any DTCs are stored like P1811. It does not trigger the SES/CEL light. You may have a pressure control solenoid (PCS) issue.
Timeslip 08/12/06
Old 03-23-2008, 05:43 PM
BNaylor, I removed the rad cap to check the color, and it is orange, but I think someone must have mixed prior to me owning the car, because there is a LOT of slug built up in the rad. (at least near the cap area) Is there any additive you would recommend to add to clear the slug up, so then I can flush the system, and add the Prestone Extended Life coolant?
Old 03-23-2008, 10:47 PM
BNaylor's Avatar
I use Prestone Super Flush. Add it and run it per the instructions before flushing. We have a cooling system flush procedure if you need it. Also, be sure to clean out the plastic coolant reservoir tank.
Timeslip 08/12/06
