Old 02-27-2003, 09:08 AM
MCLAY 90DX MCLAY 90DX is offline
1990 DX to receive 1990 Si motor...
Hi folks,
I am a newbie to this forum and a hack DIY mechanic looking for information regarding a few things.
To begin with I have purchased a donor car (1990 civic Si) for $300.00 Canadian. The wrecking yard that owns it will deliver it to me to take off what I need to do the swap and then pick it up when I am done with it.
So, what do I need to do the swap into my dx? I have heard talk of throttle cables, wiring loom and rear engine/tranny mount but need a complete rundown of what I truly need to do before I start.
Next, the Si motor will be receiving some attention while it is out, doing basic checks on it and some mods while it is on the stand. What would be some suggestions for modifications/inspections while it is out and on the stand. Both cars are manual transmission, and the DX had a clutch put in about 1000kms ago. Hoefully I can reuse this clutch in the swap.
Any help via email or this forum would be greatly appreciated.
Thanks
Mclay
Old 02-27-2003, 09:20 AM
91civicDXdude's Avatar
for starters, the donor car will need to donate its engine, transmission, ECU, fuel injection, injector resistor box, and some wiring. All of the mounts are exactly the same and your cluth will work as well.
Take a look at the Si's wiring harness to get an idea of how to rewire your existing DX harness to use with the MPFI injection. If you are still confused, there are many websites and threads on this forum dealing with converting your DX to MPFI injection.
Things to change on the engine while it is out:
timing belt
water pump
plugs
plug wires
distributor cap & rotor
any other maintenace items (filters and such)
The engine will bolt directly into your car, using all the existing mounts, linkages, etc.
If you have any more questions please feel free to ask as people on this board are eager to help another 4th owner out.
Old 02-27-2003, 09:31 AM
I didn't know that the trans would need to be replaced as well. Hmmm.
Old 02-27-2003, 09:32 AM
the transmission doesnt NEED to be replaced but it is highly recommended as the Si transmission is geared more towards acceleration and the DX tranny is geared more towards top speed/gas mileage.
Old 02-27-2003, 09:42 AM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i don't think anyone could have given you better answers
you do not need to swap the tranny...but if it is avalible, do it! well worth it...
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 02-27-2003, 09:43 AM
-grins
well, you know, i try:smoka:
Old 02-28-2003, 09:22 AM
THE SWAP
THIS BOARD IS AN EXCELLENT RESOURCE.
One more question. The throttle cables and wiring loom. Any words of advice, caution etc. I realize there are a few sites out ther covering this info as well. If anyone could provide links or additonal info I would greatly appreciate it. Keep in mind I have access to an almost complete donor car so if there is anything additionall I should take please tell me!
Thanks so much to the board members
MCLAY
Old 02-28-2003, 09:33 AM
Use the throttle cable off of the Si. The DX throttle cable *might* work but it would snake around the engine bay and be much too long. I used the throttle cable off of an HF which is the same length as the Si one.
Wiring loom i am not sure of, but because you are essentially making an Si harness out of a DX harness, im assuming you can use the factory Si wiring harness loom.
in all actuality, you could just use the Si wiring harness but i have been told it would be easier just to modify a couple wires to change the DX to Si than it would be to swap entire harnesses.
Old 02-28-2003, 02:20 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
I would use the si tranny if you have it too, i wish i had gotten one when i could for my swap....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 02-28-2003, 04:44 PM
amy@af's Avatar
Re: THE SWAP
MCLAY
first off...i'm glad you feel this place is a good reasource
all the links i found most helpful when i did my sohc vtec swap i added to the engine section at the 4th gen site....check them out...
http://www.4thgenerationcivic.com/engines/Engines.htm
all those sites seem to cover everthing from a to b. if you still have questions...please feel free to keep asking!
1990 Mazda rx7 motor in need of help pbaddict03120 RX-7 16 12-10-2006 11:38 PM
1990 3.9L Motor Swap fritolayfuel Dakota 1 10-20-2004 07:45 PM
1990 crx dx motor swap ? ashcrx '88 - '91 Civic | CRX | Wagon | Shuttlee 2 05-17-2004 07:02 PM
1990 acura integra motor??? 1990civic '88 - '91 Civic | CRX | Wagon | Shuttlee 48 05-15-2004 01:55 AM
FS: 1990 S5. New Motor, Clutch. Built, clean. flea7 RX-7 7 04-16-2004 11:48 AM
