Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 03-18-2008, 01:19 PM
chefjohn1 chefjohn1 is offline
Lens cover removal
Tried to get out lens cover on my 97gr. Marquis. I looked at the manual and it showed only one snap ring pliers piece. It came off but the lens will not come out. Do I need to also take out the snap rink holders for the adjustment screws?
Old 03-18-2008, 06:56 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Lens cover removal
Which lens cover are you talking about? You got me confused.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-19-2008, 07:10 AM
The entire head light lens. It is one solid piece that the bulbs are put into.
Old 03-19-2008, 07:36 AM
way2old's Avatar
TOKEN HILLBILLY
There should be 3 clips holding it in place. Here is partial directions from Alldatapro.
Remove three headlamp mounting clips retaining headlamp to radiator grille opening panel reinforcement. NOTE: Use snap-ring pliers to spread headlamp mounting clips, then pull straight upward to disengage.
Remove headlamp from vehicle.
Old 03-19-2008, 01:39 PM
Thank you. wish I had a picture of the clips
Old 03-19-2008, 07:15 PM
way2old's Avatar
TOKEN HILLBILLY
Wish I had a better picture for you.
Old 03-20-2008, 06:42 AM
Thank you. I do see those. I did not know if those were also holding the lens in. I thought they were to adjust the head light, and were not to be removed.
