Old 03-17-2008, 08:53 PM
rev2red's Avatar
rev2red rev2red is offline
Send a message via MSN to rev2red
Cammed Grand prix gt
hey everyone, i am new to this, but ill give it a shot. I own a 2004 grand prix gt, i currently have a Kn'N air intake and wanted to get more power for cheap and don't we all , just wondering if u guys have any ideas. I dont mean spark plugs and wires i mean like headers, exhaust, Cammed?
Old 03-17-2008, 10:22 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: Cammed Grand prix gt
i would start with the easier things such as CAI. I'm not real familiar w/ the newer models since i am more familiar w/ the 97-03 models. not real sure if the 04 has the Ubend in the exhaust, but that is another thing that would give you apx. 5HP if you removed it.
Old 03-18-2008, 09:40 PM
rev2red's Avatar
wow 5 hp just by removing U-bend? or do u mean replacing it with a straight pipe, cuz u need the o2 censor right?
Old 03-18-2008, 09:42 PM
rev2red's Avatar
apx?
Old 03-18-2008, 10:39 PM
here is a link for you, this is where i bought my Ubend delete. you can also check out the rest of the site, they have some pretty good deals.
as you can see, this Ubend delete has a hole in the side pre drilled so you can keep your OE O2 sensor.
Old 03-19-2008, 03:38 PM
rev2red's Avatar
thanx man, they do have a ton of stuff at ZZ
Old 03-19-2008, 08:49 PM
GTPpower GTPpower is offline
All 04+ cars don't have a ubend.
One thing I would suggest is a top swap. Basically, it's swapping the heads, intake manifold, supercharger, PCM, and a few other things on to your car off of a GTP.
Cammed, Headers, Tuned and other stuff
13.20@105mph @2200ft. elevation
Old 03-21-2008, 02:46 PM
rev2red's Avatar
thats a good idea, but i have a GT and dont wanna GTP or i would have bought it haha...too much labour like special oils for supercharger and servicing and need to always use Ultra octane, NOOO thanx . i just wanna make it faster then a GTP camming it is something i have considered and will be done soon, also headers and exhaust...thanx for advice! Turbo is coming soon
Old 03-21-2008, 09:22 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
here man, check this out....
http://www.zzperformance.com/grand_p...=214&catid=113
read the testimonials, might be worth a shot. Although I'm not sure if it would work with a series 3 3800.
Also might want to look into some 1.9 ratio rockers
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 03-21-2008, 09:33 PM
BNaylor's Avatar
BNaylor BNaylor is offline
What makes you think you will not need premium gas (91 octane or better)? To fully take advantage of the mods on just about any you could do you will need a reprogrammed PCM module - DHP, Intense, ZZP or Powertuner. On the issue of roller rockers I recommend the 1.8 ratio. You do not need upgraded valve springs or a hot cam and it is a good bang for the buck considering it is a bolt on aftermarket product that can be done in just a few hours time.
Turbo? $$$$ Big bucks for what it is worth.
Timeslip 08/12/06
AF Community Guidelines
Old 03-22-2008, 02:03 AM
onebadazzsrt onebadazzsrt is offline
I put slp header with the 3 inch down pipe, and took the cat off, 2.5 all the way back to the flowmaster 40 series and all I can say is wow, this thing climbs hard after 4,000. next is a cam from zzp
Old 03-22-2008, 04:43 PM
rev2red's Avatar
thanx BNaylor i will keep all of this in mind..what will roller rockers do for me and how easy is it to install? as well as onebadazzsrt thanx bro, how much was header (slp) does it sounds nice? and how much to install time and money bro?
Old 03-22-2008, 07:58 PM
the header I got was off 3800 perfomrance website and it ran about 850 with all the 02 extensions and obd11 plug for the rear, it took me a bout 3 hours to put it in, you gotta take off the whole throttle body unit to squeeze the headers in the back-unlesss you want to drop the cradle a couple of inches. The headers were the best mod I've done yet and it sounds killer. I would use zzp's gt2 cam and you can keep all your stock pushrods and lifters.
Old 03-22-2008, 08:00 PM
Oh yeah and pacesetter makes the same header know it looks like it might be a bit better than the slp, if you get it from zzp- They fixed a cuple of flaws that they had.
Old 03-23-2008, 06:41 PM
rev2red's Avatar
so pacesetter is another good one huh?...zzp is a performance shop online then?....i will check it out, i dont really know exactly what i have to do to install the header, what problems might i run into installing it and maybe later down the road, will i have to change anything else ? what Hp gains can i get from this?
