Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 03-14-2008, 09:00 AM
camaro1026 camaro1026 is offline
85 camaro v6
my 85 camaro's temperature guage doesnt work it has the 2.8 v6 i replaced the coolant temp sensor and all that did was fix my electric radiator fan i guess there tied in together there is another sensor that looks like the coolant temp sensor right beside it but i looked on autozone and advanced auto online and all i can find is the coolant temp sensor if anybody knows if the one beside it is for the temperature guage or not and what its called id really apreciate it. also i have an 89 irocz with nice rims and tires that i want for my 85 but on each one it has one that has a key on one of hte lugs but i dont have the key any ideas on how to either get em off without it or were i could find one? thanks.
Old 03-14-2008, 09:49 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 85 camaro v6
The key is available throught GM, be ready to shell out some cash. OR if you can get a pair on, very firmly applied vise grips
As the the temp, there is a sending unit for the gauge, usually on the dirvers side with a single green wire. On the 305 and 350 the other sensor to which you refer is the knock sensor, not sure on the 2.8's but usually the General works things universally accross the board.
Old 03-14-2008, 06:53 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: 85 camaro v6
http://cgi.ebay.com/ebaymotors/82-02...spagenameZWDVW
there's one for a 98-02 camaro... I'm not sure if they've changed or not
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 03-15-2008, 12:59 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: 85 camaro v6
You have 2 coolant temperature sensors. One for the gauge, and one for the computer. I can't remember which is which.. but there's ones right under the throttle body next to the thermostat. The other one is on the front end of the drivers side cylinder head. Which one did you change out already? The one by the thermostat, or the one on the cylinder head?
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 04-02-2008, 01:17 PM
Re: 85 camaro v6
i replaced the one closer to the throtle body right underneath it but looking down theres one that looks similar to the right is there another one near the thermostat? i would have to take a closer look.
Re: 85 camaro v6
Old 04-02-2008, 02:07 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: 85 camaro v6
call around to NTB, Jiffy Lube, dealerships, etc. and tell them your problem with the lug nuts. most of them should have a universal key kit, and should be able to take off your lock nuts without much hassle. probably charge an hours labor to do it, roughly 70-100 bucks.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 04-03-2008, 11:13 AM
miecow miecow is offline
Send a message via AIM to miecow
Re: 85 camaro v6
depending on the shape of the lock lug.. find a hardened socked slightly smaller than.. and baby sledge hammer it on.. use a breaker bar,,, that would be the cheapest way..ive had to do it a few times with cars i bought and didnt get the key..
