Old 02-26-2003, 04:08 PM
Hatchin Hatchin is offline
Send a message via ICQ to Hatchin Send a message via AIM to Hatchin Send a message via Yahoo to Hatchin
Arrow Audio S-10 Project, what do u think??
Sup everyone? My friend is buying a 88 S-10 off this kid at school and me and him are going to build it up audio wise. I am not that familer with S-10's but i think we are planning on making 2 large sub-enclosures that will stretch from the back to the front of the bed. The sub-enclsure will hold 4 15" subs and 8 8" subs and the other side will be the same. I have built some systems before but this will just be crazy. I was wondering what kind of speakers you would reccomend? And do u agree with this set-up? If not, what would u do?
Thanx
-Sam:smoka:
CRX Si
Old 02-26-2003, 04:16 PM
lewdaka03 lewdaka03 is offline
Are you planing on putin a tonneu cover on it??? I suggest you build the box then put it in because when you use the original bed you lose quality and moisture gets to the cones of the speakers. I would suggest you check out the interior and try to put maybe 2 10s inside the cabin they will sound real good. Is it an extended cab or did they make ext cabs back then Hit me back if you need more info!!!
KRIS
Old 02-27-2003, 03:45 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
modern subs don't generally require a lot of space, 4 15's should require about 8-12 ft^3 (2-3 ft^s per sub). Do NOT play the 8's and 15's in the same freq range .......... the 15's should run like 20-60 Hz or something like that, the 8's should run 60-150Hz or so - as a midbass, meaning the 8's MUST be in the cab. This also means you will need a 4 way crossover or a 2 way crossover feeding into a 3 way.
Old 02-28-2003, 02:01 PM
Hey paulD if he wanted to save money couldnt he sput like one 8" and one 10" Wouldnt the sound quality be better?? My dad used to own a Mazda truck that had two 10" in the bed. It just mostly provided a thump for people out side the car!!! You seem to be the tech guy can you contrast new tech to old because Im thinking about the same thing he is. except Im gonna do a ext cab and ripout the rear seats and put the subs and stuff back there..
Old 02-28-2003, 03:36 PM
Audio Guy
if you have the subs facing the outside, yea - it will just be a "neigborhood sound reinforcement system." If you cut a hole in the front of the bed and the back of the cab and port the sound thru that, it will be like having subs in a trunk or hatchback. A good setup would be 2 8's in the doors - down low and as forward as possible, and then a 15 for the deep bass.
Old 02-28-2003, 05:13 PM
GT-R4life GT-R4life is offline
Just curious, how did you plan on powering your original setup?
Wires shorted out...i think. MikeyB772 Car Audio 1 06-29-2010 02:03 PM
next project what do u think? turbo2nr Car Modeling 5 07-07-2003 01:25 PM
My new project. What do you think? Juan Robles WIP - Street 10 07-05-2003 05:44 PM
