Old 02-26-2003, 01:58 PM
xxdcmast xxdcmast is offline
Exclamation Center Console
Was wondering if anyone knows how to remove the center console in a 2000 standard cavalier. First of all how do i get the shift knob off. Then how do I remove the entire center section including the armrest and cupholders
Old 02-26-2003, 02:16 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
To remove the shift knob there should be a U shaped retainer holding it in on the front part of the knob, use a small flat blade screw driver to lift it out.
Console Replacement Chevrolet
Removal Procedure
Open the console compartment.
Refer to Trim Plate Replacement - Console in order to remove one of the following components:
The console trim plate - automatic transmission Disconnect the shift indicator connector.
The boot - manual transmission
Remove the screw cover (7).
Remove the screws (6).
Remove the console (2).
Installation Procedure
Install the console (2).
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the screws (6). Tighten
Tighten the screws to 2 N·m (18 lb in).
Install the screw cover (7).
Refer to Trim Plate Replacement - Console in order to install one of the following components:
Close the console compartment.
Removal Procedure
Gently pry upward on one of the following components in order to disengage the retainers: For automatic transmission, the console trim plate (1) and disconnect the lighted shift indictor connector.
For manual transmission, the shift lever boot (2).
Align the retainers.
Press one of the following components into place:
For automatic transmission, the shift indicator connector, the console trim plate (1).
Old 02-26-2003, 03:30 PM
thank you exactly what I was looking for
center console? j.fuggi '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 01-20-2002 05:37 AM
Lights in center console jrjkw 3 Series 1 01-11-2002 03:54 PM
need a new center console... ky_infiniti2000 Cosmetics 8 12-20-2001 06:47 PM
taking off center console face ... mAtC '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 14 12-18-2001 05:33 PM
1980 320i Center console-3 pc-dark blue-EBAY chetleech 3 Series 0 08-11-2001 09:49 AM
