Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 03-03-2008, 03:24 PM
slim8and75 slim8and75 is offline
Angry shifting cable maybe?
I have a 92 gm and I went to drive it and the shifter went up and down and wouldn't shift? It has alot of play but wont shift? Help me out. Is there a cable or pin or what should I look up. Let me know another web site to look at if you can.
Old 03-03-2008, 07:10 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: shifting cable maybe?
Look at the bottom of the steering column inside the car. There is a bracket that is held in place with 2 little bolts. See if these are loose. If they are, tighten them with a T15 torx bit. If they are tight, there is a possibility the shift tube in the steering column has broken. If that is the case, let us know and we can search the information and post the repair. Also check at the transmission where the cable attaches to be sure it is tight.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
