Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 02-29-2008, 08:55 PM
Bonzjivar Bonzjivar is offline
Unhappy 2001 GM speed control
Hello! My 2001 GM speed control worked intermittently yesterday. Today it is DOA. There are no recalls on my model. So I assume it is not going to be repaired gratis by Ford. I have the Haynes Repair Manual, but it just skims over the cruise control. Anybody have any suggestions or experience as to what the is most likely cause? I have looked at the switch on the master cylinder and it is still there! Brake lights function OK.
Any suggestion will be greatly appreciated
Old 03-01-2008, 11:45 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 2001 GM speed control
Here are the diagrams for your system. Find out where the current stops and you have the place you need to repair. On the Crowns, we have found the clockspring in the steering wheel or the servo under the hood. Also chewck to see if pins 6 and 10 on the cruise module are connected to a good ground. Use a meter to see if there is continuity toi ground. Good luck.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 03-01-2008, 10:50 PM
HEMIDAZE's Avatar
HEMIDAZE HEMIDAZE is offline
Just because Ford has not recalled your model does not mean that is does not have the same cruise control switch that has caused Ford to recall millions (yes millions) of cars with the defective switch that may cause your car to catch on fire. The list gets added to every few months and your car may be on it soon. GOOGLE it. These are just a couple.
http://www.safetyforum.com/fordcruisecontrol/
http://www.fordfires.com/
HERS---> 2006 Grand Marquis GS (replaced my 1998 w/cracked manifold)
HIS----> 2003 Dodge 1500 HEMI QC 4X4
Old 03-03-2008, 08:53 PM
Thanks much. Actually more information than I hoped for! Trouble is intermittent again. This will make diag so much easier.
Old 03-03-2008, 08:55 PM
Thanks for the links. gotta keep an eye on these.
