Old 02-24-2003, 10:47 PM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
A tip that will make it WAY easier for those of you making custom body kits ...
A tip that will make it WAY easier for those of you making custom body kits out of putty...
When you putty up the body, you wait until it dries than you sand right? When you sand, does'nt the bumper chip a little? Then you have to reputty, and sand agian...
Use Tamiya X-21 flat base to fill up those litte chiped holes. The cap is clear on the bottle.
I hope this tip has helped alot of you and made it easir to do your custom body jobs...
Old 02-24-2003, 11:44 PM
impreza2k2's Avatar
impreza2k2 impreza2k2 is offline
thanks for the info
so how can i apply them on? paint it on with brush or do i have to use airbrush?
thanks
Don
Current project:
Mini Cooper S, 350Z, Nismo R34GTR, Atlezza, Miata
Old 02-25-2003, 04:28 AM
flyonthewall's Avatar
Car Mod guy
As myself and others have said many times, use styrene!!!! Its not all about slapping on a load of putty and seeing what sticks!
Imagine you are creating a skelton of the bodykit out of styrene, the putty is the flesh, filling in gaps, creating contours and smoothing over areas.
Hope this helps
Old 02-25-2003, 05:02 AM
pcmodeler's Avatar
pcmodeler pcmodeler is offline
I agree with Chris. Please don't take this the wrong way, but some of you guys are going pretty heavy on the putty. Either use styrene, or there are other products, such as balsa foam. If you do it right, you may be avle to cast yourself a master from resin. For projects I've done, I've also used balsa wood covered with a thin layer of styrene for the basic shape. I then cast that in resin and do my more detailed shaping on that. Putty is a filler, not a builder.
Old 02-25-2003, 05:52 AM
espin espin is offline
You get much cleaner body lines with styrene. You don't have to end up sanding everything together on your body kit.
Craig
Click here for more pics!
Old 02-25-2003, 07:27 AM
pcmodeler's Avatar
The other advantage to using styrene is that nothing else sands like styrene (Duh).
What I mean by this is the following. Different materials have different levels of hardness (Duh again). However, that also means that the softer materials will tend to sand quicker than harder materials. This means you can actually end up removing more of the softer materials than you really intended. A good example is using superglue as a gap filler (which I do all of the time). The superglue, when dry, is harder than the surrounding plastic. This means that when sanding, I will need to work harder to get the superglue to level out to match the plastic, and may result in my removing more of the surrounding plastic than I wanted.
Depending on the putty, it may be harder or softer than the plastic used in making the model.
Old 02-25-2003, 07:41 AM
erix7's Avatar
erix7 erix7 is offline
Re: A tip that will make it WAY easier for those of you making custom body kits ...
... Use Tamiya X-21 flat base to fill up those litte chiped holes. The cap is clear on the bottle...
I prefer using super glue for filling small dents and chips: Flat Base has no bonding agent, so it
gets powdery and wears off when it has dried.
Super glue gets hard fast, you can sand it some 15 minutes after applying. Don't put a big blob of super glue on the model though and be aware of blooming (white residue on surrounding parts, especially metal bits).
HTH,
-- Eric.
Old 02-25-2003, 10:34 AM
sugarcaddy's Avatar
sugarcaddy sugarcaddy is offline
yeppers I agree with everyone else about strip plastic. Nothing beats it. You can get all sorts of different shapes and designs premade and apply them to your kit.
Not to knock putty-but Ive tried it and IMHO I don't like the feel or texture of the putty. It just doesn't look right and it never turns out right for me. For those that make it work-ROCK ON!
I for one love strip plastic :frog:
Scott
Fastest hunk of junk in the Galaxy.....
Old 02-25-2003, 01:09 PM
integra818's Avatar
flyonthewall, sometimes styrene won't work and you have to use putty, and when you get a small chip, I would use either the flat base or the superglue like mentioned before.
A few tips that will save you money on a "99 Rodeo V6 dfr4444 Rodeo | Passport | MU 0 02-19-2007 08:47 AM
1995 Civic DX Looking for Custom Body Kits LostWages Exterior | bodykits | Lighting 2 11-10-2005 01:24 AM
*CUSTOM Body Kit* For Sale progressiv_edge Monte Carlo 0 04-27-2004 06:38 PM
Acrtic Blue Civic Si w/ custom body kit!! espin WIP - Street 33 06-26-2003 06:04 AM
Clean or Custom Body kit For a 626 SiXPuSHA Street Racing 0 09-15-2002 12:49 PM
