View Poll Results: Should you change rear brake linings with 4MM.left on them? Can I get 10,000 Mi more
change now 0 0%
should I get more then 67,000 Miles from them with normal driving? 0 0%
Voters: 0. You may not vote on this poll
Old 02-22-2008, 06:23 AM
Marion Van Hal Marion Van Hal is offline
Question Gas Mileage
My gas MPG has droped to 12-13 mpg with strictley town driving with my 2002 3800 v6 Buick LeSaber. It is in the cold IA weather. What could my problem be? Should I get the 17MPG? Thanks
Old 02-22-2008, 12:18 PM
vgames33 vgames33 is offline
Re: Gas Milage
If you went from some highway in warm weather to all city in the cold, then its believeable. Until your car warms up, you are in craptastic MPG mode (otherwise known as open loop), which helps everything warm up faster.
Your tires may also need more air since its cold outside. I'd also look into a tune up and air filter change, since the car is 6 years old. How many miles are on your car?
Old 02-22-2008, 12:57 PM
Re: Gas Milage
I carry 36 lbs in the tires. [New tires]The filter should have been checked the last I had it serviced but will check it. There is 63,000 Miles on the car.
The last tank has been all small town driving ar 12-13 MPG. I hope to get it out on the road again befor long. I got around 24 MPG on the last 2000 mile trip. Was also somewhat cold then.
Thanks Marion
Old 02-22-2008, 02:07 PM
j cAT j cAT is offline
Re: Gas Milage
short trip driving in very cold weather less than 30deg f will cause a huge drop in mileage......sudden drops in temp you have to check tire pressures as they will drop considerably.....in warm weather 24mpg is normal at 60-70mph.... at 90-100mph it will drop to 20mpg........
Old 02-22-2008, 02:20 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Gas Milage
Really cold air is very dense, and can cause more gasoline to fall out of suspension. As a response to that the EFI injects more fuel. Combine that with the fact that winter blended fuel is up to 15% ethanol (which has less energy and density) and mileage can go in the dumpster.
Dragging people kicking and screaming into the enlightenment.
Autopro1962 Autopro1962 is offline
Re: Gas Milage
A new fuel filter can help I replaced a lot with 30000 miles that are pluged solid and if you are letting it warm up that also will effect MPG.
Old 02-22-2008, 03:31 PM
Re: Gas Milage
Correction on milage. The Buick has 67,000 miles on it. I just checked the tires. They have 35 lbs pressure but it is a little warmer today. [24 degrees] It hasn't been much above 10 degrees for a couple weeks.
Thanks again.
Old 02-22-2008, 05:24 PM
Re: Gas Milage
fuel filter replacement will not improve gas mileage..........but if your fuel filter was plugged it will make you fuel pump happy...........
Old 02-22-2008, 10:30 PM
Re: Gas Milage
WOW!CLUELESS
Old 02-22-2008, 10:36 PM
UncleBob UncleBob is offline
AF -Advisor
Re: Gas Milage
if a filter is 100% clogged, the car won't even run autopro
If its clogged enough to reduce supply to less than the demand, it will at the very least, cause the AFR to go lean at high demand and/or cause it to misfire and stumble under high load.
You could definitely argue that worsens the mileage, but so does disconnecting 4 spark plugs, or any number of mechanical problems you can throw on the table. Its a runnability problem at that point, not just a mileage issue
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 02-23-2008, 09:34 AM
Re: Gas Milage
Hey!All I'm saying is check your basic maintenance items,air filter,fuel filter,tire pressure,if the check eng or service eng light is not on that probaly all your going to get MPG,you could try to use reg.unleaded.
Old 02-23-2008, 11:58 AM
Smile Re: Gas Milage
Thanks to all for the advise.
Marion
Old 02-23-2008, 09:34 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Gas Mileage
After trying all those things, head back out on the highway for a bit to see what your mileage is. If it's not back up to where you'd expect it, then let us know.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 03-31-2008, 10:58 AM
Smile Re: Gas Mileage
I finally got back on the highway after helping my wife while healing from a broken hip.
On a 100 MI. drive I got 27.4 mpg. On mixed driving I got around 20 mpg.
Includes a couple drives of 32 and 100 mi. The cold weather and the all town driving must have been most of the cause for the 12-13 mpg.
Thanks Marion
Old 03-31-2008, 03:34 PM
Re: Gas Mileage
Thanks Marion
that mpg looks normal...so your vehicle is running very good still at 70,000mi...
if you haven't , change the fuel filter every 30-40,000mi. this will keep your engine and fuel pump from problems..
