Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 02-17-2008, 11:24 AM
bobcoop06 bobcoop06 is offline
Send a message via AIM to bobcoop06 Send a message via MSN to bobcoop06 Send a message via Yahoo to bobcoop06
'98 CVPI Rear End
I need to replace the rear end in my 98 CVPI. I'm having trouble locating somewhere that has a used one off of the same car. What other years or models will fit without much trouble or fabricating? And if it comes down to, how hard is it to replace the gears (considering it has traction control)?
Old 02-18-2008, 05:49 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: '98 CVPI Rear End
I believe from 98 to 02 will interchange easily. The gears are not that hard if that is all you are replacing. Ring and pinion and spiders are still just remove , replace and adjust.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 09-04-2008, 11:34 PM
lights_sirens's Avatar
lights_sirens lights_sirens is offline
way2old,
I checked the rear end fluid on my '98 with 138K and it's full. The rear end does not make any noise.
My owners manual says the factory fluid is full synthetic and only requires changing if the fluid gets water in it. Do you change the rear end fluid on your P71's, or can I leave it alone?
Old 09-05-2008, 02:14 PM
way2old's Avatar
TOKEN HILLBILLY
If you have full synthetic grease, there is no need to change it. However, if the vehicle has been run through deep water, there has been water intrusion and needs to be changed. We change ours about every 30k miles since Police do not what the sign "HIGH WATER" means. Have fun.
