Old 02-11-2008, 03:15 PM
j cAT j cAT is offline
opti spark distributors which one's best
when the weather warms i plan on r/r the water pump and opti on 96 impala. which manufacturer should i use. i would like positive and negetive comments on all manufactered opti"s. also which store/internet source to buy. the original opti is still working . thanks to all replies.....
Old 02-11-2008, 05:11 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: opti spark distributors which one's best
I've heard good things about the MSD, but I don't think they're any better than the factory. The factory optispark is wonderful on the "opti" side (the optical triggering) but not so reliable on the "spark" side.
They also sell cap and rotor kits to refurbish your original.
Dragging people kicking and screaming into the enlightenment.
Old 02-11-2008, 08:26 PM
auto zone sells these MSD opti's it states that it is unlawful to install the msd 83811 opti for street use. do you think it is because it has adjustable timing screw ? +/- 5deg ? also i have read that , the MSD coil , when used with the opti , causes problems with the rotor/cap , because of the increased voltages created....have you installed or own vehicle with this distributor ?
Old 02-11-2008, 08:46 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Here's a link to a setup I was considering installing should the Optispark in my Roadmaster fail:http://www.delteq.com/. I was told that the same item is available for about $135 less at paceparts.com.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
