Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-08-2008, 05:58 PM
fordnut02 fordnut02 is offline
98 regal no start/code 1610,1626
need help with 98 regal gs 3.8 supercharged .
going down the street running fine , shut down . wouldn't start back , had it towed , scanners shows codes 1610 and 1626 .
fires fine no fuel pressure .also tryed to reset key .
help ?
gene
Old 02-08-2008, 06:11 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 98 regal no start/code 1610,1626
Welcome to AF.
I'm assuming that is P1610 and P1626.
DTC P1610 Loss of PZM Serial Data
DTC P1626 Theft Deterrent Fuel Enable Signal Lost
It sounds like your PCM module went South but check the fuses feeding the PCM first.
Timeslip 08/12/06
AF Community Guidelines
Old 02-09-2008, 11:20 AM
any other tests I can run ?
Old 02-09-2008, 11:53 AM
BNaylor's Avatar
DIY? Probably not. I believe a GM Tech II scan tool will be required for advanced diagnostics
Timeslip 08/12/06
