Old 02-23-2003, 05:57 PM
BlueCivic83's Avatar
BlueCivic83 BlueCivic83 is offline
Send a message via AIM to BlueCivic83 Send a message via Yahoo to BlueCivic83
how do you check your error code
hi i just bought an 89lx today and was wondering how to check my engine error code is the blinking on the cpu itself ?
Old 02-23-2003, 05:59 PM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
Yes, there is a glass light in the middle of your ECU...turn ignition on without starting the car and watch as the light on your ECU will blink. Example: Long blink followed by 3 short ones is counted as 13...Count the number of blinks and post for more info.
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 02-23-2003, 06:20 PM
Civic Rush's Avatar
Civic Rush Civic Rush is offline
Send a message via AIM to Civic Rush
Are you sure. I belive that the long blink is to tell you that it is on and then it will blink so many times. and that number will tell you what one. Cause if it is the way that you say then I am in trouble cause My car is throwin a 26. DAMN thats a big number.
Old 02-23-2003, 06:30 PM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
yea and mine would b throwing a 30 thats NUTS!
Old 02-23-2003, 10:34 PM
EF_LSVtec's Avatar
read it the way you want but the long code is counted as 10 in any book. I had 2 long blinks and 3 intermittent ones for my knock sensor (23)
AF Bay Area Crew
Retired SOLD 1/08
Old 02-24-2003, 01:46 PM
ok it's code 6 i read its coolant temperature
what can i do for that ?
and also to resset it I read that you should remove the hazard fuse for 10 secs were is it located ?
and what number is the fuse in ?
Old 02-25-2003, 10:37 AM
EF_LSVtec's Avatar
I'm not sure exactly but you have 2 fuse boxes...under your steering column and in the engine bay (right hand shock tower), just check it out.
You can also unplug your ecu and that'll reset it.
AF Bay Area Crew
Retired SOLD 1/08
how do I check for error codes? ry1820 F Series 2 01-15-2010 06:15 PM
2005 Grand Cherokee- How to et the error code ? amari Grand Cherokee | Grand Cherokee SRT8 1 02-04-2006 09:13 PM
Checking your ECU codes and clearing them 101 ric '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 11 11-17-2005 02:53 AM
Tips on how you fix paintwork errors Captain Mark Car Modeling 6 11-09-2004 10:31 AM
how do you check your coils frijoleop Engineering/ Technical 9 08-02-2004 04:44 AM
