Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 02-05-2008, 11:20 PM
shady1070 shady1070 is offline
2000 Grand Marquis With Broke Speedometer
I still have not figured out why all the sudden my speedometer stopped working. Is there anything I can check before I change the speed control regulator. I talked to a mechanic and he said it should not be the speed control regulator because My Cruise Control still works. Before I change it, Is there any fuse or relay that might be out? My panel is not digital it is needle driven.
Regards
Old 02-06-2008, 11:29 AM
miamibob's Avatar
miamibob miamibob is offline
Re: 2000 Grand Marquis With Broke Speedometer
Is the Speedo cable connected at both ends? If so, it could be a bad cable....MB
Old 02-06-2008, 11:45 AM
Where IS it located on the other end. I checked by the speed control regualtor under the car and made sure it was secure. Where is the other end located.
Thanks
Old 02-07-2008, 11:58 AM
miamibob's Avatar
I would check where it enters the Instrument Panel and the other end should be in the Transmission. Not sure on your year so get a GOOD manual to find out for certain...MB
Old 02-09-2008, 01:41 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Your speedometer runs on electric impulses recieved by the computer. There is no speedometer cable. Look in the Battery Junction Box (under the hood fuse panel) and check fuse number 8. This supplies current to the speedometer. Lewt us know. Good luck.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 02-10-2008, 12:15 PM
miamibob's Avatar
WAY2OLD is "dead on" (as usual)! I misread the post and thought you had a '90 and not 2000! There is NO Speedo Cable and he has told you to look in the proper place - let us know how it turns out!! MB
Old 03-06-2008, 09:05 PM
rhandwor rhandwor is offline
If the fuse is good their is a sending unit usually on the tailshaft which counts pulses as the drive shaft moves. Look for a broken wire or plug.
Old 10-10-2009, 07:06 PM
Ive got a problem Ive got a problem is offline
The speedometer in my 1995 Grand Marquis quit working. This thread did it form me. I replaced the 30 amp maxi fuse in the under hood fuse panel and now everything is working properly. Thanks.
Old 08-17-2018, 12:34 PM
meanpr meanpr is offline
I replaced a 30A breaker that was shorted out, I don't think it was for the speed/odometer. I also changed the speed sensor in the tail of the transmission. Neither one has fixed the speed/odometer, anyone have any other ideas?
Old 08-17-2018, 06:10 PM
https://www.justanswer.com/ford/1aza...ode-4r70w.html
Old 08-17-2018, 09:39 PM
Originally Posted by rhandwor View Post
Neither the speedometer nor the odometer are registering at all, the speedometer needle doesn't move and the odometer and trip counter don't increment.
Old 08-18-2018, 01:02 PM
If the wiring is good some times you have to get a junk yard instrument assembly. If you have the proper tool you can check for pulse at the connection to the instrument cluster. You can get a free scan at Auto Zone or Advanced and check for codes. But need a good scanner to go further.
Old 08-18-2018, 03:17 PM
I have a bluetooth scanner that I use with Torque Pro, the car wasn't showing any codes. I'm not sure how to check the wiring, need to research more how to get that done. I see used instrument assemblies on Ebay from $50 - 90, I'll probably go that route if the wiring checks out.
Old 08-18-2018, 06:04 PM
If you can find both ends you can use a couple gem clips and an ohm meter. You may need help to have someone else hold one end. You can use copper wire so the leads can get to each end.
Old 08-29-2018, 10:36 AM
I used Torque Pro and drove around the block, it showed the speed of the car. Does this mean the wiring is OK, I know that means the data is getting to the OBD, I assume that means the wiring is OK? Can anyone confirm if I am making an accurate assumption?
