Old 02-04-2008, 09:43 PM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
Cruise Control Quit
Cruise control has stopped working ('93 3.1L) Checked fuse and it's still good. what should I check next? thanks
This ain't your grandma's car!!
Old 02-05-2008, 06:49 PM
loosenut74's Avatar
loosenut74 loosenut74 is offline
Send a message via Yahoo to loosenut74
Re: Cruise Control Quit
brake lights working?... brake light switch out of adjustment? try holding "up" on the brake pedal and setting it... that dont work come back and let us know...
Removed by Moderator
Old 02-05-2008, 09:19 PM
Blue Bowtie's Avatar
Registered Offender
Also check the bulbs in the center high mounted brake light. In some later years, the logic for the cruise grounds through the lamp filament to permit the cruise servo to latch in.
Old 02-05-2008, 11:38 PM
gw84's Avatar
I'm glad you all asked about the brake lights. I had a couple of brake lights out recently. Upon replacing them I noticed that there appears to be a short somewhere because the bulbs would work when they were held in a certain position and wouldn't when left hanging. THey're back in their socket now and I believe that they all work [I'll double check]. I didn't think about the center high-mounted taillight. Will check that too as well as the pedal thing. What do you mean by checking to see if the "brake light switch out of adjustment"?? where's this switch?
thanks!
