Old 02-03-2008, 08:51 PM
GloriaH GloriaH is offline
4604/41te Transmission
I have a 96 Caravan. The transmission stopped working. I need to know the location of the ground strap so I can check it. Also should I check the wire splice from the Solenoid and the TCM/EATX. Thanks
Old 02-03-2008, 10:47 PM
tempfixit tempfixit is offline
Re: 4604/41te Transmission
Ground strap should be located on a trans bolt in the starter area.
Can you give us a description of what tranny is doing or not doing. Is check engine light on? IF so check for codes by using the key dance method; on/off, on/off, on without starting engine.
Is battery in good shape? Battery terminals and cable ends shiney clean.
Old 02-03-2008, 11:50 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
The wire splice question has popped up several times and no one seems to be willing to say. SOMEBODY PROVE ME WRONG.
If you don't get your answer try pulling the harness apart starting at the TCM and follow it to the splice.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 02-04-2008, 08:44 AM
Driving along, turning a corner then bang, trans stopped working. I have no gears. Starts fine, put in gear, rev it up and the trans makes a slight knock. The code says... shorted or open condition detected in one or more of the idle air controll motor circuts. I thought I would start with the splice and strap before thinking about a new transmission. If I find the splice I will make darn sure I post it here...Gloria
Old 02-04-2008, 06:34 PM
wafrederick wafrederick is offline
Banned
Do not get a reman from Chrysler and I heard about it lately.Chrysler puts on a chincy paint job on their remans with dirt on the case.Probally ful of dirt inside too.Their warranty is a 3 year,80,000 mile warranty.Jasper is cheaper than a Chrysler reman and has a better warranty,3 year 100,000 mile warranty and it is nationwide.It sounds like the beginings of the spider gear pin coming out and will ruin the case if not caught in time.This is a common problem too.Jasper fixed this by welding the ends of the spider gear pin to the final drive case
Old 02-04-2008, 07:42 PM
twistedtech twistedtech is offline
I would think the pump shaft sheared and it has granaded. i have 2 laying on the shop floor, same symptom. Did you ever hear a whine?
If it ain't broke.......screw with it till it is.
Even at a Mensa convention,
Someone's the dumbest person in the room.
Old 02-09-2008, 05:26 PM
We can't seem to find the ground strap. Where can we find a good manual on how to rebuild this transmission. We can't afford to have it replaced and need to do it ourselves.
Old 02-09-2008, 07:49 PM
The battery is not in good shape. We are charging it now. What concerns us is the fact that it made a bang before it stopped working. We are going to start with the easy stuff first. I just ordered a book by Cliff McCormick called Chrysler 41te/A604, Rebuild Procedures. Hope it helps. Still can't find the ground strap.
Old 02-09-2008, 08:40 PM
You could make a new ground putting end of wire onto a transmission mount bolt by the starter area and attach other end to firewall.
Old 02-09-2008, 08:44 PM
Will try that in the morning.
Old 02-10-2008, 03:20 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Your idle air control motor/valve code has nothing to do with the tranny. It has everything to do with a stalling engine. Are you sure you're not having an engine stall issue instead of a tranny issue? When you take your foot off the accelerator to slow down at a corner, the IAC maintains the engine idle speed. You said it then started fine. That tells me the engine stalled. The code indicates the IAC may have failed causing the stall. Just want to make sure.
Old 02-11-2008, 08:53 AM
Take a look at this thread, it has a picture of ground wire for transmission:
http://www.automotiveforums.com/vbul...d.php?t=887787
Something I would try before removing trans if you have not already removed trans is disconnect the return transmission fluid line at the trans cooler, insert line into a bucket and have someone start engine and put in drive to see if the oil pump is working or shaft has broken like twistedtech suggested.
Also if and when you overhaul transmission be sure to install a rebuilt or new torque convertor, new lines to trans cooler and flush transmission cooler in radiator to rid system of all contaminetes. Installing a new trans cooler and bypassing old cooler would also work.
Hope this helps
Old 02-11-2008, 09:46 AM
4breezes 4breezes is offline
The picture I posted in my thread shows the ground wire. Apparently it is a wire rather than a ground strap. I'm not sure, however, that a broken ground wire would make your transmission quit. My Caravan still runs and moves without that ground being connected. At worst it goes into "limp-home" mode, ie no higher than 2nd gear.
That ground wire is located near the front driver's side corner of the car. Its in front of the engine/transmission, underneith the starter, about in line with where the engine and transmission meet. Hope that helps you find it, and that a bad ground might solve your problems.
The previous poster gave you a link to the picture.
Old 02-19-2008, 02:53 PM
HeadlessHorseman1 HeadlessHorseman1 is offline
How much did you pay for a Jasper tranny? Thanks.
Old 05-01-2008, 10:19 PM
I found a ground strap attached to the firewall but the other end was attached to nothing. Can't find a ground attached to the Trans bolt. Could this be it?
