Old 02-03-2008, 05:13 PM
gm_classic's Avatar
gm_classic gm_classic is offline
Stalls in drive not in reverse
I came off the highway the other day and stopped at the light. When the light changed and I tried to ride off, the car stopped as though the brakes where applied. the (abs) light came on and the car died. I took the abs fuse out, cranked it and it died again in drive. It doesn't stall in neutral or reverse but has a slight vibration in reverse and a clatter from the idler.
****I unplugged the connector from the transmission and the same problem persists. Any help would be appreciatted****
Old 02-03-2008, 06:33 PM
Blue Bowtie's Avatar
Registered Offender
Re: Stalls in drive not in reverse
What year? (Diagnosis may be different.)
Old 02-03-2008, 10:10 PM
gm_classic's Avatar
Oh sorry it's a 93', no codes although I had a maf code 2 weeks ago
Old 02-04-2008, 07:47 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Can you explain the above in more detail? This is probably not the cause of the engine stalling, however, if it is the A/C compressor, who knows?
Old 02-04-2008, 09:34 PM
gm_classic's Avatar
the idler is moving a little too much causing the clattering sound in reverse. I had to be jumped three times in 2 days because of a grounded audio wire, and I think the computer could have been affected
Old 02-04-2008, 09:51 PM
HotZ28's Avatar
AF Moderator Elite
I think you just found the answer your own problem!
Old 02-22-2008, 05:40 PM
gm_classic's Avatar
Well I tried a new computer, didn't work. I changed the fuel regulator beause there was a fuel odor in the vacuum lines. Fuel pressure and vacuum measured okay. Pvc valve rattles pretty good Right know Im Checking for any grounded wires.
Old 03-04-2008, 03:22 PM
gm_classic's Avatar
Update on the symptoms, if I floor the pedal in drive it will move 3ft. before acting like its shifted into park and abruptly stopping cold in its tracks. Anyone know where I can find a rebuilt tranny cheap I'm in miami.
Old 03-07-2008, 08:57 AM
Master01 Master01 is offline
If the transmission isn't electronic then you might want to try the vacuum actuator on the front of the transmission.
Inside every small problem is a large problem struggling to get out.
