Old 02-03-2008, 05:51 PM
daveid daveid is offline
4wd not working
I have a 95 gmc sierra and the front wheels dont turn when I have it in 4wd. I looked down at the driveshaft and its just spinning even when the brakes are on? Are the gears maybe stripped?
thanx
david
Old 02-03-2008, 07:18 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: 4wd not working
a common problem was the electric servo motor that engages the transfer case. That would be where I would check first. If the gears were stripped you would have heard horriffic grinding and it would have been a long-time progressive problem.
Dragging people kicking and screaming into the enlightenment.
Old 02-04-2008, 12:56 PM
Re: 4wd not working
THANKS!! Do you have a quick way to be able to check it or how to check it? IVe never delt with 4wd nor much of chasis work.
thanx
Old 02-04-2008, 02:33 PM
curtis73's Avatar
Re: 4wd not working
Honestly no. I always opted for the manual transfer case cause I'm too cheap
If the driveshaft were spinning as you drove, but no power was getting to the front wheels, I would suspect the hubs, but since you said you can just spin the driveshaft, that means the transfer case is not going into 4wd.
Old 02-05-2008, 01:07 AM
Re: 4wd not working
sorry, i explained wrong. it is spinning while driving and not driving. its not spinning by hand or anything. but once its in 4wd then the front drive shaft just keeps spinning.
thanx again
Old 02-05-2008, 06:11 AM
curtis73's Avatar
Re: 4wd not working
Ah... OK, then its probably the hub engagement servo. Its another common issue. When they went to the automatic hubs there were problems with the servo that engaged them.
Old 02-05-2008, 04:20 PM
Re: 4wd not working
is that what is also reffered to as a actuator? Thanx for all the help. this isnt the first time youve helped me and i appreciate it
david
Old 02-05-2008, 04:57 PM
curtis73's Avatar
Re: 4wd not working
Yup. I think the parts book calls it "servo; actuator, front axle"
Old 02-08-2008, 03:37 AM
Re: 4wd not working
Thanx. that was exactly it. Glad it was so easy to find and replace.
thanx again
