Old 02-03-2008, 03:04 AM
drewz7046 drewz7046 is offline
Unhappy a/c blower fans only run on high speed
I just bought a 01 caravan sport with the front and rear climate controls. The problem I'm having is BOTH fans only run when the fan controls are at the High position. Having more experience with Generic Motors vehicles, I'm thinking it's the resistor block for the fan controls. Am I right and if so, where are they? Thanks a lot in advance for your help.
Old 02-03-2008, 03:18 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: a/c blower fans only run on high speed
Yes, it's likely the resistor block. The front blower resistor block is up behind the glove compartment. Not sure on the rear.
Read through this book of a thread. Might be there somewhere: http://www.automotiveforums.com/vbul...d.php?t=340871
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 02-19-2008, 03:38 PM
HeadlessHorseman1 HeadlessHorseman1 is offline
Yeah, it's tough being the most-viewed, most-posted thread in the forum. But hey RIP, think about all the repetitive work it saves you... and all the new poster signups the forum is getting. Good stuff, right?
Here's another labor-saving thread you may wish to bookmark...
http://www.automotiveforums.com/vbul...d.php?t=538591
Cheers!
Old 02-19-2008, 04:33 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Check your PM re. Are two messages necessary? You delete yours. I'll delete mine.
Old 02-21-2008, 10:49 PM
chubzzam chubzzam is offline
Some car/van's use a fuse and relay on the resistor side that protect the circuit.. that control ur low, med/ 2nd med. check ur fuse and relay first for continuit on a digital meter reading. if they read good it has to be ur resistor.. u said ur High contorl works and thats good because its another series circuit, it have a fuse & relay that work..
