Old 02-02-2008, 11:15 PM
speed5676 speed5676 is offline
I4 or H4
does a configuration of an engine affect the power or horsepower of a car? like I4 or H4, does the configuration of these engines matter but has the same cylinder capacity
Old 02-03-2008, 02:24 AM
UncleBob UncleBob is offline
AF -Advisor
Re: I4 or H4
Power isn't a real factor between the configs. The real advantage to H4 is lower profile and less inherent vibration.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 02-03-2008, 05:30 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: I4 or H4
Sometimes they do, but its minimal. For instance, most I4s have 5 main bearings while most opposing fours have 3 mains. It could be argued that the extra support on the crank helps reliability, but it also saps some friction.
But for the most part, an H4 and an I4 will both make the same basic power and torque if you compare equal parts.
Dragging people kicking and screaming into the enlightenment.
Old 02-03-2008, 11:00 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: I4 or H4
I have heard that inline engines tend to have more torque than other configurations. I don't buy that though as I believe it has more to do with the intake, exhaust, and head design than the piston configuration. So, if someone tells you that, I wouldn't believe them.
