Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-29-2008, 11:18 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
disappointing drive today...
well, after all that shit i went through, removing the exhaust housing, braking all 4 bolts, shipping to slowboy, paying for them to do nothing, paying a local shop to drill/tap the holes in the turbo and porting it, and installing a cat... I"M STILL GETTING BOOST CREEP! though i can tell that it is MUCH better! its still bad, i have boost set to 15psi, in 3ed gear by about 4500rpm i'm around 17psi, and only got to 5k where i was close to 20psi, since my car is not tuned to run that kind of boost... i'm back in square one, only $250 less in my pocket... i'm so pissed, i wanna just put back on the T25... its almost that bad! WTF?
Old 01-30-2008, 12:02 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: disappointing drive today...
Why did you go through all that and not get a bigger flapper?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-30-2008, 12:35 AM
Black99GST's Avatar
i was told at the time that the small flapper is fine, the bigger ones blow open after 17psi, and after tuning and such, i'm hoping to run more around 21-26psi... but i'm not their yet... if i creap to 20psi from 15psi mbc setting, you think it will hold 21psi to redline if thats where its set?
Old 01-30-2008, 07:37 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
You should have just went to an external wastegate the first time then you wouldn't be having these problems.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-30-2008, 08:12 AM
Thor06's Avatar
Jizzed In My Pants
Sounds like someone gave you some shitty advice, I'm pretty sure the bigger flapper is commonly regarded as the solution to creep. Since the Talon is going to be DD'd I am going to have to cool the plans on that hard, but a bigger flapper so I can actually make a redline pull is something I would absolutely do if I have to take out the turbo.
But yes, you are right... when you are creeping to X psi and you have it set at X+2 or whatever, it shouldnt be creeping. On that note though, I dont know what boost it'll hold to redline though, being a smaller turbo it might fall off.
Old 01-30-2008, 08:21 AM
Holset powered 420a
Dustin - I believe it was Kevin that told him about the bigger flappers blowing open a little on higher boost.
Here is the thread, if you also read what Kevin says you shouldn't be running 15psi either.
http://www.automotiveforums.com/vbul...d.php?t=772353
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-30-2008, 12:00 PM
Thor06's Avatar
Jizzed In My Pants
Wow, fuck. Me = pwned. Funny thing is, I swear I read that Kevin said that the bigger flapper IS a good idea... my bad .
Old 01-30-2008, 12:32 PM
Black99GST's Avatar
well i'm still creeping with external dump o2 and the cat... fuck me!
Old 01-30-2008, 03:00 PM
george536's Avatar
george536 george536 is offline
external gate > you
lol
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 01-31-2008, 09:47 AM
kjewer1 kjewer1 is offline
AF - Advisor
I also posted like 5 years ago that the external dump O2 housings are worthless for reducing boost creep, but no one listened then either.
I don't know what's been done for porting, but that's where all the boost level reduction comes from. If you're sure you're porting it properly and you're still not getting results, make sure there is nothing mechanically wrong. Test the actuator with an air compressor and a 5 dollar pressure regulator and gauge. Run with no boost controller to eliminate that. Etc.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-31-2008, 12:05 PM
Black99GST's Avatar
keven, info on port found here
Old 01-31-2008, 01:08 PM
AF - Advisor
Ok, I remember now. It could still use a lot more porting IMO, if it's still like it is in the pics. What did it go to SBR for, more porting or something else? If you can afford a few weeks downtime, send that POS to me and I'll drag it over the finish line. This is a one time offer though.
I do have friends and local club members that run completely unported housings without creep, but I'm pretty sure all of them are running ~20 psi daily anyway. If you really want to run like 15 psi, it takes a crap load of porting...
Kevin Jewer
Old 01-31-2008, 01:38 PM
steviek's Avatar
steviek steviek is offline
I get a couple psi creep at about 22 which takes me into 24 region with a ported exhaust housing but I don't mind I just account for it
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 01-31-2008, 01:50 PM
Holset powered 420a
I think the biggest problem is that the flapper wont open 90 degrees. I back when I had an internal wastegate the actuator came disconnected from the flapper and that thing wouldn't build but maybe 1psi of boost. I think if yall could find an actuator with a longer push that would open the door more the problems would be solved with very little porting.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 01-31-2008, 03:31 PM
Black99GST's Avatar
once i get my DD this will be a definate "will do" for me, however, i am not planning on running 15psi, i'm actually wanting to be more in the 23-26psi range or well, whatever it takes to max out flow on the E316G... just havent got the time to tune it, and as for now, its a daily driver, so i dont really need to be driving to class with my computer trying to tune, and doing pulls and end up with a blown ICP... or worse... so, only time will tell... but if the offer still stands when i have another DD, i will for SHURE take you up on it!
