Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-23-2007, 01:21 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
e316g ported and ready to go!
well, after a little more then a month i (hopefuly) have all the kinks out, and HOPEFULY after this long, LONG, painful process, when i put it all back together tomorrow afternoon, i'll be running creep free! here are some pics of the porting as promised...
the inlet *note the holes for the bolts... OH yeah!
close up down the inlet:
decided while i was at it to let the wastegate open up a full 90* so... ported a little their to...
check out that perfect fit!
another pic of the inlet:
gasket match is almost perfect!
well, anyone have any inside about boost creep still being a problem with an External dump o2, and a full 3" turbo back (no cat)?
Old 12-23-2007, 12:22 PM
steviek's Avatar
steviek steviek is offline
Re: e316g ported and ready to go!
Nice port job musta taken a while. Good job. I think your boost creep will be out the door.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 12-23-2007, 03:40 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Good job man. Should work out for you.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-23-2007, 04:12 PM
Eclipse4ever's Avatar
Eclipse4ever Eclipse4ever is offline
To tell you the truth I never noticed or even understood boost creep when I still had a Big 16G and when you switch to external wastegate you finally understand what boost creep meant and how good it was without it. I would prefer external WG over internal any day, only bad things is the dump tube which might take a little fabrication. 16G is the ultimate street turbo for me. Always loved it. Very nice on the porting job.
1997 Eclipse GSX
Old 12-23-2007, 06:10 PM
Black99GST's Avatar
external W/G=$$$ unless you want to sell me your set up for $25 shipped, i'm perfectly happy with my port job! thanks for all the replys guys, hope it all works out great... doent look like i;m going to be able to get everything up and running today, but i'mma atleast take a crack at it.
Old 12-23-2007, 11:42 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
What'd you port it with, and what grit did you polish it with? It looks like it could be polished a little more so you don't get carbon buildup, but other than that it looks awesome, great job!
95 Talon TSI AWD
97 Eclipse GST
Old 12-24-2007, 01:58 AM
Black99GST's Avatar
ported it with a f*ing dremel... took FOREVER! and i gave up on polishing, because i had already spend FOREVER porting it, so i just did a quick sh!t with some mag polish and called it done! got everything on the car tonight, but i'm back at my parents house for xmass, so i dont wanna take it for a drive and piss everyone off so late.
Old 12-24-2007, 05:22 AM
I just polished my turbo and it took me 2 days. Also the intake manifold and fuel rail took me a day. I never want to polish again ever.
1997 Eclipse GSX
Old 12-24-2007, 06:09 AM
kjewer1 kjewer1 is offline
AF - Advisor
With the right equipment polishing will take less time. But it's not cheap to get all the right stuff.
Porting so the flapper can open all the way is only good for getting more access when porting the WG hole. The actuator won't open the flapper any further than it usually does.
On the outlet side, the divider between the main exhaust and WG exit area is way too thick IMO. I had to scoop that out all the way to the main exhaust passage, leaving just enough to get a little bit of gasket in there (port the gasket to match) and to not crack hopefully.
On the inlet side, as you look down the wall that intersects the WG inlet passage, you can cut a shallow trough into it so more of the exhaust gasses "catch" the WG passage on their way down. I can't guarantee that this won't affect WOT flow at full boost when the WG is being used very little or not at all, but it never seemed to hurt my performance. It did however provide a noticeable reduction in boost creep on other turbos.
With a dremel I don't think you can make the necessary changes mentioned here, it will just take you too long. I'd try it the way you have it, and if you still have problems at 20 psi (see other thread), pull the housing and get a die grinder and do it right. At one point I could have the turbine housing off and being ported in less than 10 minutes. The turbo can stay in the car BTW.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 12-25-2007, 10:27 PM
Black99GST's Avatar
if it still creeps, i wouldnt be able to ship it off to you and have you do the port work could i? i would be willing to pay for the work...
Old 12-26-2007, 03:40 AM
AF - Advisor
Hmm. I would almost consider it. Almost.
Kevin Jewer
Old 12-26-2007, 10:46 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
WITH A DREMEL?! Holy shit son, I ported mine with an acutal fucking die grinder and I think it took me a solid 3 days of 8-14 hour days to get my head, manifold, turbo, and o2 sensor housing done.... and the head and manifold took about 3 hours total because they were just gasket matched and slightly opened up. Now doing it with a DREMEL, that takes commitment.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 12-26-2007, 09:07 PM
Does the dremel still work after all that? Shit, mine gets hotter than a pistol after like a 1/2 hour of using it.
95 Talon TSI AWD
97 Eclipse GST
Old 12-27-2007, 01:40 AM
Holset powered 420a
I burned my last dremel up when I was painting my brakes. I grinded all that textured shit off of them.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 12-27-2007, 02:39 AM
steviek's Avatar
what is it about dremels that just makes them so fun to use haha
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
