Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-26-2008, 06:57 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Fog Lights????
How on earth do you replace the fog lights in a 2000 grand prix GTP? I had one burn out and I bought two new silverstars as replacements. Just cant figure out for the life of me how to reach them short of removing the bumper. Its 0 degrees here for a high, so I cant be freezing my fingers off trying to replcae fog lights, but I'm not paying someone to do it.
Also how is the bulb removed from its lense? Twist, pull? I dont want to break anything. These cold temps make plastic brittle.
One more question, when I was at wal-mart deciding what bulbs to buy, the little information center said the 2000 GP takes an 880 bulb. 880 bulbs use 27Watts. There were also other bulbs there that seemed to have the same electrical socket but had different wattages. Anyone experiment with these type of bulbs? I think there were two, one had 35 watts and the other had 50 watts. Would buying the 50watt bulbs make my fog lights brighter? Could my wiring system handle it without overheating? Thanks!!!
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 01-26-2008, 07:58 PM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Re: Fog Lights????
It can be tricky to change them out, especially in sub freezing weather where ice build-up can make them stubborn to pull. They do twist and pull. If at all possible do it in a heated garage and the front tires up on a ramp/ramps or wait until the weather warms up a bit.
From behind the fog lamp and under the bumper you can access the wiring/ bulb and twist counter clockwise. Usually the socket needs a budge (On Mine) to loosen it so I have used needle nose pliers to get it going, careful not to damage the wires/connecter, using a small flashlight helps to see where to grab up there.
When I have to change them in winter I throw my gloves in the dryer on high for five minutes before I go out.
As far as higher wattage bulbs I'm not sure but I've heard that anything higher than stock can melt the housing.
Good luck and stay warm. We were hovering in the single digits but had a warm front come through, we're up to a hot 30 degrees...Can't wait til Spring!
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 01-26-2008, 09:39 PM
tblake's Avatar
In God We Trust
Re: Fog Lights????
Thank You!! Great suggestions!
Old 01-27-2008, 09:16 AM
bigstakz bigstakz is offline
Re: Fog Lights????
I figured out how to change mines but now they wont come on. The switch is lighting up but lights are not working. Where could I possibly locate the fuse if one exists?
2001 Pontiac Grand Prix SE 3.1 V6
2000 Chrysler Concorde LXi
Old 01-27-2008, 09:51 AM
tblake's Avatar
In God We Trust
Re: Fog Lights????
I think there is a relay and also a fuse in the underhood fuse box on the drivers side.
Old 01-27-2008, 03:21 PM
Re: Fog Lights????
I will check that out, thanks.
Old 01-31-2008, 11:44 AM
hercman hercman is offline
Re: Fog Lights????
Silverstar fogs won't last long. If it's not too late take em back and exchange em. Otherwise you'll be changing them again in a month or two. Everyone I know who put SSs in their GPs were having to replace them with in three months.
Also if you don't wanna go under the car to change the bulbs if you remove the headlight you can reach down and change em.
Old 01-31-2008, 12:20 PM
buff6116 buff6116 is offline
Re: Fog Lights????
I would not go up in watts with the fog lights i tryed that on my 98 Bonnie and it killed the car. Melted the hot positive wire from the fog lights to a ground buss ground in the main harness and fryed a lot of stuff out like fuel pume and power windos. I know its a different car but i will not do that again.
Old 01-31-2008, 04:54 PM
phaelax phaelax is offline
Re: Fog Lights????
I just put the SS fog lights in my '00 gtp, and I must say they're not worth the money at all. Hardly any noticable difference between them and the OEM fog lights. They still even appear a yellowish color. SS is a waste of money if you ask me.
'00 Grand Prix GTP: KYB struts (Gone, trade-in)
'02 300m (R.I.P. Dec '07, the Uhaul won)
'03 Jaguar S-type R
'73 Duster
Old 01-31-2008, 08:50 PM
tblake's Avatar
In God We Trust
Re: Fog Lights????
I have SS headlights and love them, but if you guys arent happy with ss's for fogs, I'll return them. If they have a yellow tint, They are going back, I cant stand the yellow tinted headlights. Want blue, anyone recommend any fog lights that will give a real real bright white or blue light? On ebay maybe?
Even looking for blue headlights, but it seems everywhere I look, they have "blue" headlights, but on the box it says that they "produce brilliant white light". False advertising?
Thanks for the input!!!
Old 02-03-2008, 08:41 PM
tblake's Avatar
In God We Trust
Re: Fog Lights????
I just put in my silverstars, Thanks averyone for the help. I do think they are brighter than my stock ones.
Old 02-03-2008, 09:15 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: Fog Lights????
you bought the Sylvania Silverstar foglight bulbs? I'll let you know, that was a $40.00 mistake. they are only gonna last 3 months...if your lucky
the headlight bulbs are nice though. for some reason the fog bulbs dont like to last very long. I went through 3 pairs before i decided to just give up. they are bright as He!! though!
Old 02-03-2008, 10:20 PM
tblake's Avatar
In God We Trust
Re: Fog Lights????
we'll see how long they last. Let you know
Closed Thread
