Old 01-26-2008, 04:02 PM
wrexink's Avatar
wrexink wrexink is offline
Send a message via MSN to wrexink Send a message via Yahoo to wrexink
Diorama building help.
Well I am gonna make a garage diorama! The demensions are 27"x18" with a store front and the garage in the back and 2 garage doors. I need some tips on building supplies. Like what should I use for walls Whatever material is going to be sandwiched between to sheets of poly stiren on the inside it will look like brick on the outside of the garage it will look like aluminum siding. As many tips as possible will be helpful. Thanks! BTW. it is a 1:24th scale
My MySpace> www.Myspace.com/stuntit
Old 01-26-2008, 04:20 PM
Adam Baker Adam Baker is offline
Send a message via AIM to Adam Baker Send a message via MSN to Adam Baker Send a message via Yahoo to Adam Baker
Re: Diorama building help.
If your going to sandwich the walls, then I think I'd probably use foamcore board for the walls, which will help save a ton on weight.
From there, you might want to take a look at Walthers. They are a large model railroad supply company, but they may have structural steel members like you would find in the roof of a typical auto shop, and you could probably use those to show a few roof members for realism.
Also take a look at Evergreen & Plastruct. Both are manufacturers of sheet styrene. AFAIK both of them make structural steel shapes in plastic, that could come in handy for ya.
Old 01-26-2008, 05:01 PM
wrexink's Avatar
Originally Posted by Also take a look at [URL="http://www.evergreenscalemodels.com/"
Evergreen[/url] & Plastruct. Both are manufacturers of sheet styrene. AFAIK both of them make structural steel shapes in plastic, that could come in handy for ya.
Thats the only stuff that our hobby place carries. and what is this Foamcore stuff? Pics would help to! thanks
Old 01-26-2008, 05:23 PM
Foamcore board is usually sold ins 15"x24" sheets and around 3/16" thick, and you can get them at Michaels, Hobby Lobby, WalMart, etc.
Its a medium density type foam, w/ something similar to cardstock paper on both sides of the board. It cuts pretty easily using an x-acto knife or a box cutter, and its fairly rigid, but the really nice thing is its light, and fairly cheap.
This is what it looks like
As you can see, the medium density foam in the middle, w/ the cardstock on both sides.
Old 01-26-2008, 05:32 PM
wrexink's Avatar
Thanks! what should i use for the floor now? On top of it is going to be tile
Old 01-26-2008, 05:36 PM
freakray freakray is offline
AF Modelrater
A thread posted in the past week which you may find useful:
http://www.automotiveforums.com/vbul...d.php?t=883641
AF User Guidelines
Old 01-26-2008, 05:37 PM
wrexink's Avatar
here are the plans roughly
Old 01-26-2008, 06:11 PM
I think I'd probably use 1/4" or 3/8" plywood for the base. Nice & sturdy, but not extremely heavy.
On top of that you have all kinds of options. Paper, putty, dirt, styrene sheet, etc, for your ground terrain.
Old 01-27-2008, 06:50 PM
wrexink's Avatar
Ok i got that foamboard stuff and some plastic I beams and everything else. I also got all the doors and windows cut out. how should i make the walls stand?
Old 01-27-2008, 07:08 PM
AF Modelrater
Have you tried glue?
AF User Guidelines
Old 01-27-2008, 07:19 PM
wrexink's Avatar
would that be sturdy enough?
Old 01-27-2008, 08:06 PM
AF Modelrater
Depends on the type of glue you use. It's kind of hard to give you advice when you're not exactly clear on what you're trying to do.
AF User Guidelines
Old 01-28-2008, 06:57 AM
Your going to have to use something to reinforce the joints, whether its nails, or wire, or what not, that will run between the 2 pieces at the corners. Take the nails, and where you lap the joints, run a nail through one piece, into the edge of the piece its lapping over. I'd do it ever couple of inches, just for support.
And then you'll want to use some kind of glue as an adhesive. I'd look at using something like Gorrilla Glue, or something similar to that. You'll probably want somethign thats pretty high tack, so it will have the strenght you need.
Even w/ this, you'll want to be very careful, b/c it wont be the strongest joint in the world. It should be fine as long as it doesnt get hit or jostled around a lot. You'll want to assemble as much as you can before putting the building together, that way you arent reaching into hte completed structure more than you absolutely have to. Put all your details on your walls, get it all glued in place, and then start assembling the structure.
