Old 02-21-2003, 01:29 PM
ajroc ajroc is offline
timing belt change - when should i?
When should I have my timing belt changed? My owner’s manual tells me 105K depending on driving conditions but I have seen other boards that recommend changing at 60K.
Thanks
Old 02-21-2003, 01:38 PM
dirk-diggler's Avatar
dirk-diggler dirk-diggler is offline
Banned
60K sounds right, 100K is really pushing it. Easier just to change the belt cause if that belt breaks, well, you'll replace the belt and a whole bunch of other crap.
Old 02-21-2003, 04:02 PM
strodda strodda is offline
and if you werent already planning to, you should also change your water pump, so you dont have to pay for labor twice. and if you want to do a little performance tuning, have them throw on cam gears as well. no point in paying for labor more than once.
Idle hi/lo when started after timing belt change Bachan Prelude 6 11-20-2009 08:41 PM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
What all should be done with timing belt change? CaelanT ZX2 2 02-15-2008 12:57 PM
Hard starting after Timing Belt Change - Runs Fine when started? LeidenK Let's get Technical! 3 11-28-2006 12:21 PM
Timing hi/low when engine started after timing belt change. Bachan Engine 0 12-19-2003 09:35 AM
