Old 02-21-2003, 03:14 AM
90hbvtec's Avatar
90hbvtec 90hbvtec is offline
B16a1
what is need for a swap in a b16a1 in my hatchy...can i use my stock axles..?.. can i use my clutch cables..? my gas cables... u tell meeh..will do swap soon...cause i strip my drain plug on my tranny i think i over tighen it so im piss shit dont want to tighen.gonna put JB weild up in that b*tch...so im saving up for a b16a1 swap... need some inputs...
tru sohc vtec......
d16z6,ractive intake,ractive wires,msd ignition system w/blaster2
obx headers,pacesetter catback, w/test pipe,arospeed bomb muffler,tockico illumina shocks,r1 coilovers,GSR blades rims,ebay short shifter, w/neuspeed bushings,neuspeed strut bars front n back,ingalls camber kits altezza lights,indiglo gauges,proform shift light,integra center console..thats it for now...what else do i need...??ummmmmmm..TURBO..!!!!
Old 02-21-2003, 03:16 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Short answer? You need everything and then some... keep saving
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 02-21-2003, 03:28 AM
90hbvtec's Avatar
ummmmmmm thanks....
tru sohc vtec......
Old 02-21-2003, 04:01 AM
Setanta's Avatar
Well... it beats saying "use the search function not to menton the stickied links" which have this info in it
'99 PY DC2R
'85 BBS BMW E30
Old 02-21-2003, 06:19 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
no you cannot use your stock axles, you need axles from a 90-93 integra, i was told that the stock clutch and throttle cable from a si will work, but idk for sure. since you wired for the z6, idk how you did it, if your running the si stuff or if you changed the wiring to odb1, idk what youll do for wiring, youll need the motor mounts, shiftlinkage. it will run you about $2500 for all the parts and everything if your doing it yourself, it will run you about $3000 at a shop so you wont need to worry about buying all the parts cause they do everything. idk thats all i can think of
Old 02-21-2003, 12:49 PM
VelocityCivic91's Avatar
VelocityCivic91 VelocityCivic91 is offline
Send a message via AIM to VelocityCivic91
I got a quick question, what model 90-93 Integra ( LS, GS, RS, GS-R ) axels fit a JDM B16a1. My axels are clicking sooooooo bad, and I thought that you could only use B16a1 axles. Let me know ASAP, cuz that clicking noise is... LOL, "driving" me up the wall. Sorry, didnt mean to get off topic. Thanx
WARNING: Surgeon General says it's O.K. to smoke V-8's.
*** Looking for a B&M fuel pressure regulator and guadge***
Old 02-21-2003, 12:53 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Integra LS axles
Old 02-21-2003, 01:41 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
www.hasport.com will tell u the list of things you need.
Old 02-21-2003, 01:55 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
Check this out for your ECU i will be doing this when i get the z6
2002 Acura TL Type S
1991 Honda Crx Si
Old 02-21-2003, 04:03 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
The 90-93 teg axles work...so long as you aren't using the SiR Y1 intermediate shaft (it's longer) like I am.
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Need help identifiying jdm b16a1 sensor! zipperheadk Engineering/ Technical 12 03-13-2008 02:27 AM
What Is Needed To Get B16a1 Into High 13's All Motor? UMREX '71-'87 Civic | CRX 14 03-11-2002 01:37 AM
b16a1 in 5th gen. hatch? Poweredbyhonda '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 02-20-2002 12:20 AM
