Old 01-19-2008, 04:55 AM
kapp0 kapp0 is offline
2004 GTP Bad Gas Mileage
I know this question gets asked a lot, but here it goes. When everyon talks about gas mileage in here they never mention if they are getting the reading from the onboard readout or if they are calculating themselves. I have an 04 GTP and the computer is showing 16.3 average. My wife drives the car 90% of the time so it isn't getting driven hard at all. Why would it be so low? I've read through as many mileage posts on this board as I could find, but haven't come up with a solid answer.
Old 01-19-2008, 08:45 AM
Burtnette Burtnette is offline
Re: 2004 GTP Bad Gas Mileage
Can't help you much but I'll try to get some information so others can help you easier. How many miles are on the car and have you modded it at all?
CURRENT:
1997 Grand Prix GTP
Mods:
U-bend/Res Delete
3.4"
MSD 8.5mm
TR6s
ZZP 1.0 PCM
72mm TB w/ TB spacer
WizAired CAI
3" DP w/ Borla Pro XS mufflers
OLD:
1995 Dodge Stealth
Old 01-19-2008, 08:57 AM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
Try re-setting it if you can. I always reset mine especially on the highway. In Winter I get about 28-30 mpg at 70 mph and a little more in Summer.
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 01-19-2008, 11:40 AM
Sorry, here is more info. It has 52,000 miles. I just got it about 4 months ago. It got the throttle body replaced about three months ago, I hoped that would fix the bad mileage.
How do you reset the mileage calculator?
Old 01-19-2008, 11:43 AM
If your talking about the one in the DIC then all you have to do is push & hold the reset button on the left while in the mpg mode and it will reset.
CURRENT:
1997 Grand Prix GTP
Mods:
U-bend/Res Delete
3.4"
MSD 8.5mm
TR6s
ZZP 1.0 PCM
WizAired CAI
OLD:
1995 Dodge Stealth
Old 01-19-2008, 07:53 PM
phewop118 phewop118 is offline
Hmmm. I think it may help mileage if it is driven so that during acceleration, some boost is used. When cruising, keep the foot as far off the accelerator as possible or use cruise control. So, give it more gas to get up to speed quicker and then stay the hell off the gas pedal. Seems to work for me. On 100 mile trip in my 07 GT I averaged 28mpg, about 60% highway. On everyday use, the car gets about 22mpg, which includes a lot of rush hour driving.
Current Cars:
2001 Oldsmobile Intrigue GLS 154k miles
2005 Chevy Trailblazer EXT LT V8 145k miles
2005 GMC Yukon XL SLT w/Autoride 86k miles
2007 Pontiac Grand Prix GT 77k miles
2007 Cadillac DTS Lux II 47k miles
In Limbo:
2003 Oldsmobile Aurora 4.0 - got side swiped while parked, waiting on insurance decision
Recent Past:
2007 Hummer H3 5-speed Lease was over 7/17/10
Old 01-19-2008, 08:09 PM
22mpg is where I would like to be with it. I reset the mileage average. I will try to remember to check back later with the results. If anyone has more advice, I'll definitly try it.
I have to say that this car does make it really difficult to stay off the gas.
Old 01-22-2008, 05:05 PM
What brand and octane of fuel do you use? I would recommend using only BP or Shell 93+ octane.
Current Cars:
In Limbo:
Recent Past:
Old 01-22-2008, 07:23 PM
Those are the two stations we rotate between. The car seems to really like the Shell gas. I have given up the gas mileage fight until this cold weather breaks. The car spends too much time warming up to get a fair result. These below zero wind chills are murder on the mileage.
Old 01-22-2008, 08:15 PM
Same here... and I'm averaging about 15 right now driving the best I can
CURRENT:
1997 Grand Prix GTP
Mods:
U-bend/Res Delete
3.4"
MSD 8.5mm
TR6s
ZZP 1.0 PCM
WizAired CAI
OLD:
1995 Dodge Stealth
Old 01-23-2008, 01:26 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Dummy question.... Are your guys' tires inflated corectly? How about overdrive? I realize it will take longer to go into overdrive when its -40 windchill, but does it go into overdrive? Im in MN when the highs for the past couple of weeks have been 0-5 degrees. I average roughly 17.5 to 18mpg with warm up time.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 01-23-2008, 04:37 AM
I've been checking mine once a week and keeping them at 30 pounds cold/32 pounds warm per the instructions on the inside of the trunk.
Old 01-23-2008, 01:57 PM
Yes, I have to fill my front left one up about once every 2 weeks and the others hold the air pretty well. I'm not going to mess with getting new tires though since I have different ones for the summer which will hold the air 10x better which I'm hoping will improve my gas milage a decent amount. And wait how does overdrive work on the Grand Prix? On my old car (95 Dodge Stealth) there was a button to turn overdrive on or off and I don't see one on the Grand Prix.
CURRENT:
1997 Grand Prix GTP
Mods:
U-bend/Res Delete
3.4"
MSD 8.5mm
TR6s
ZZP 1.0 PCM
WizAired CAI
OLD:
1995 Dodge Stealth
Old 01-23-2008, 02:42 PM
bricker82's Avatar
bricker82 bricker82 is offline
That's cool but if they're not stock tires, check the manufacturer recommendations too. I run mine at 35 PSI hot, and I say hot, cuz it gets hot in AZ, lol. Still it shouldn't make that much of a difference.
04 GTP CompG 3.8L Supercharged
K&N FIPK/180Tstat/SSC Springs/GMPP STB's/Autolite APP605's/Aluminum Grilles/SPO Tips/17" AE Alloys 185's/2 RockfordFosgate He4410 Subs & 1 P4002 Amp
Old 01-24-2008, 02:44 PM
je2345 je2345 is offline
Exclamation Re: 2004 GTP Bad Gas Mileage
i drive a 99 GT and it has about 95,000 mi on it, and i only get about 13-15 mpg. It sux..i reset my odometer every time i fill up and my last reading was 225 miles to a full tank of gas. That is Garbage, and my tires are farely new Pirelli's with Nitrogen in em!! I take good care of it and give it what it needs...full synthetic Mobile1 oil changes every 5 months or so and just got the Tranny rebuilt! New Ceramic Brakes and everything!!!! I also use Fuel injection cleaner prolly 3 times every 2 months here and there. FU** DOMESTIC CARS...cant wait til my wife buys her 08 Honda CRV, so we can drive that and save me money on gas!! if ne1 has any ideas on how to solve my terrible gas problem, then let me know please!
