Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-18-2008, 05:33 PM
BigLou101 BigLou101 is offline
corner lights
i recently purchased crystal clear corner lamps and now i found out there are two types one with cornering lamp and one without can anyone explain the difference currently mine have one bulb and its a turn signal is that a cornering lamp or would a cornering lamp be a second bulb in the assembly
Old 01-18-2008, 05:37 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: corner lights
Could you translate this into English, please?
In other words, it's painful to read this without an attempt at grammar and punctuation.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-18-2008, 05:42 PM
Re: corner lights
Sorry i was in a little hurry. MY problem is that I ordered a set of corner lights. Which are set up for cornering lamps. Someone mentioned that my current set up is not set up for cornering lamps. My current corner assembly has one bulb in the very rear of it over the amber reflector. Is this a cornering lamp or not. Sorry if it makes little sense.
Old 01-18-2008, 05:47 PM
silicon212's Avatar
Confoundingly Lucid
Re: corner lights
What year is your car?
Cornering lamps are clear, bright lamps at the bottom of the fenders, on the sides that light up solid when the turn signal is selected for that side. You see these lights on higher-end American cars such as the Caprice Brougham, Cadillacs, Lincolns, Mercury etc.
You're probably thinking of a side marker lamp. This wraps to the side from the outside of the headlight doors.
Old 01-18-2008, 06:36 PM
463's Avatar
463 463 is offline
Re: corner lights
lamp should look like this one. the clear side is for the cornering lamp that turns on when the running lights are on and the signal light is turned on. the amber is the marker lamp thats on when the running lights are on. With your crystal clear corner lamps they will require a amber bulb to replace the clear bulb thats there now. check the rpo code in the trunk to see if the car came equipped from the factory
T87 : LAMP, CORNERING lamps. here is the link for your rpo codes 91 caprice. I did this on my sons car 4 years a go good luck and welcom to A/F http://www.marshu.com/images-website...-car-codes.pdf
Old 01-18-2008, 06:56 PM
Blue Bowtie's Avatar
Registered Offender
Re: corner lights
Old 01-18-2008, 07:52 PM
Re: corner lights
Ok Thanks I will need to tie in another bulb to fit with the assemblies I ordered i guess i can tie them in with the side marker or turn signal somehow. My car is a 91 9c1 350 caprice ill have some pictures once the corner lights and new grill are on it.
Old 01-18-2008, 07:58 PM
Re: corner lights
Ok so according to the RPO numbers mine was not equipped with the cornering lamps just side markers. And By the way if anyone is looking for a used set of head light assemblies and side marker assemblies, W/O cornering lamps they're yours free if you can pay shipping.
Old 01-18-2008, 08:40 PM
Registered Offender
Re: corner lights
Do not parallel them with the side marker lamps. You can't even use the same ground, since they ground through the turn signal filament of the turn/park lamp near them. The cornering lamps must have their own circuit, otherwise they will flash lust like the side markers, and very dimly at that. You might be able to use a logic module to operate them. Otherwise, you'll have to replace or rewire the turn signal switch.
Old 01-18-2008, 09:24 PM
Re: corner lights
what if I parrallel them with the turnsignals on the headlight assembly
Old 01-18-2008, 09:46 PM
463's Avatar
463 463 is offline
Re: corner lights
if your good with auto wiring you could use this link infromation to compleat your cornering lamps:http://www.6066gmcguy.org/turn-off-light.htm
Old 01-18-2008, 10:08 PM
Re: corner lights
thanks 463 that should help alot
Old 01-18-2008, 10:57 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: corner lights
I know it's off topic, but Blue Bowtie, It's good to see you're keeping your car stored this time of year as opposed to letting the salt attack it.
Old 01-18-2008, 11:26 PM
Registered Offender
Re: corner lights
The factory method:
Pete,
I keep all the summer cars stored. Three of them have never even seen gravel, let alone salt:
Old 01-19-2008, 09:07 AM
463's Avatar
463 463 is offline
Re: corner lights
now to keep on seeing we used
9004SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen High & low beam headlamp -Parking light
2057AST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style Front sidemarker # 24 NA heres a link for your car http://www.sylvania.com/ConsumerProd...RG-Results.htm
