Go Back   Automotive Forums Car Chat > Buick > Regal
Old 01-17-2008, 09:50 AM
dwaynlakrz dwaynlakrz is offline
Angry water leak
hi everyone---i have a water leak on the right side of my car under hood-how can i tell if its the water pump or the heater core there is no water on the floor inside the car -there is no hoses busted or leaking? it appear to be alittle behind the water pump but i cant see the water drip--- 1999 regal 138000 gs supercharged
thanks
Old 01-17-2008, 10:45 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: water leak
Is this water leaking or coolant? You should clarify. If coolant you could have a bad seal on the water pump and it is leaking out the weep hole. Other possibility is the lower intake manifold gaskets or the 90 degree plastic elbow located between the LIM and tensioner (heater bypass).
Timeslip 08/12/06
AF Community Guidelines
Old 01-17-2008, 03:21 PM
Re: water leak
its coolant --i think its my heater core-- its leaking from the firewall drain hose i think
thanks
Old 01-18-2008, 08:26 AM
BNaylor's Avatar
Re: water leak
That doesn't sound good. If you are sure it is coolant and not water leaking out the HVAC drain hose from condensation then I would agree possible heater core. PITA to replace though.
Timeslip 08/12/06
Old 01-18-2008, 06:08 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: water leak
Are you sure the leak is coming out the HAVC box? Could it be a heater core hose from the tensioner to the heater core spraying coolant back to the firewall & draining down the firewall. Usually, a bad heater core will leak to the inside of the cabin!
