Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 02-20-2003, 10:47 AM
Flux Flux is offline
Oil Changing and Maintenance Plan
I have a 330xi on the way and was told that it needs an oil change every 15k miles or so, depending on when the service indicator says so. I plan to keep the car for a long time. Should I change the oil more often myself and take it to the dealer only for scheduled service (covered by the maintenance plan)? Or should I just trust the indicator and change it only when it says? what would you do?
If I do end up changing it myself, should I use the same oil and filter the dealer uses?
Thanks for any input.
Old 02-21-2003, 08:02 PM
bjchacha bjchacha is offline
Changing oil frequently is the cheapest insurance you can buy on the longevity of your engine.
I change oil between 3000 and 5000 miles, depending on use, season, etc. I think you can go longer if you use synthetic oil, but I'd never let it go 15,000 miles under any circumstance.
I don't think there's a lot of difference between filter brands - use what you can find. I buy them on the web 1/2 dozen at a time.
Old 02-22-2003, 01:37 AM
redimpss5 redimpss5 is offline
i live out west where we dont really get cold, but i have been using redline for years now, and i change it every 15k. redline says it can go 18 k, but i can remember 15 easier. i use the k&n oil filter and change it every 7500. my engines dont even burn oil, and pressure is a tad higher. plus the 9 horsepower on the rear wheels (on the dyno) is a plus) i do have one car i dont drive much and it gets a change every year.
american component's russian component's all made in taiwan!!
Old 02-24-2003, 01:43 AM
badboy325is badboy325is is offline
oil change
i wouldnt let the change go longer than 5 to 7k. you can get the filter at autozone or anywhere really. i have a suggestion if you are gonna change your own oil. get you a code reader and reset tool from bavarian auto. they are sweet because you can reset your lights yourself and also check for fault codes in your beemer
Mechanic Oil Change Mishap parkca01 Engineering/ Technical 7 01-21-2011 05:26 PM
99.5 Jetta overheating after oil change kate_m '97 - '03 1 03-27-2010 11:06 AM
Oil change and Air Filter for 2003 GA GT Cossack Grand AM 1 09-24-2004 11:15 AM
Oil Change and service indicator djbpmlaw 3 Series 13 02-16-2003 09:53 PM
