Old 01-12-2008, 11:14 AM
mansopoor mansopoor is offline
97 4xr4 wont ingage
i have a 97 blazer 4x4 4.3 vortec, 3 button 4x4 switch. ok i was stuck on some ice in my driveway so i put it in 4x4 hi, the back tires spun but the front tires didnt move, so i put it in 4x4 low, and again the back tires spun and the front tires didnt, i could hear it shifting when i pushed the buttons but the front tires dont move, it seems like it wont come out of 2 wheel drive
Old 01-12-2008, 02:05 PM
wafrederick wafrederick is offline
Banned
Re: 97 4xr4 wont ingage
There is a diapraghm under the battery tray,look for a torn boot or it could be defective.It is a common problem and is a dealer part only which goes for a hundred dollars.
Old 01-12-2008, 02:26 PM
ok thank for the info, but here is something eles for you. on the drivers side up by the firewall i had a vacume hose that is not attached to anything and is sucking not blowing. it is about 4in. long with a tee in it. one of the hoses goes to the intake were the brake booster goes and the other hose goes around the back of the motor and goes down by the heater core. i dont think this is the problem but it could be cause i cant get me vents to change now. to bring you up to speed i just done the intake gaskets and the problem started after i got everything back together.
Old 01-12-2008, 02:42 PM
old_master's Avatar
Advisor/Moderator
That vacuum line goes to the 4WD also and may just be your problem. If you need the actuator,
the Dorman part # is 600 102. Any auto parts store can order it. Autozone has it for $50.
http://www.autozone.com/Ntt,600%2010...BE9CA26FF5C9D5
Advance Auto has it for $42. http://www.partsamerica.com/ProductD...tNumber=600102
Old 01-13-2008, 09:34 AM
ok i can now give you a pic of the vac. line that i'm taking about. were you see my hand is on the drivers side up by the firewall, and sorry about the pic, i had to put it trough facebook cause i cant figure out how to do it through AP
http://www.facebook.com/photo.php?pi...9&id=612960013
Old 01-13-2008, 09:37 AM
ok never mind the link it doesn't not sorry
Old 01-14-2008, 09:29 PM
BlackBlazOn BlackBlazOn is offline
Check your vacuum hoses. Make sure you can pull a vacuum on them. If not, replace any cracked or dry-rotted hoses. Check the vac actuator under the battery tray as described above. Disconnect the negative battery terminal for 1/2 hour. This should reset the x-fer case computer. When you push the buttons on the dash for 4WD, what do the lights do? Do you hear the motor on the transfer case try to engage the gear?
2000 Camaro SS, LS1, Pewter, T-Tops, M6, leather;
1999 Monte Carlo LS, 3.4 L V6, Pewter
1997 Blazer LS, 4.3L Vortec V6, 4WD, Black, BFG All Terrrain TA KO's
