Old 01-01-2008, 07:57 PM
chevy64454 chevy64454 is offline
Question Missing on 2 cylinders
I have a 2000 cavalier 2.2L. It suddenly began missing cylinders 1 and 4. I have ignition, fuel and compression, but it just won't level out. Any assistance with this would be greatly appreciated.
Old 01-01-2008, 08:34 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Missing on 2 cylinders
How did you check the ignition and fuel? Compression numbers?
Old 01-01-2008, 09:46 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
I am not sure about your specific car, but many GM cars use one ignition coil for two cylinders, meaning that if one coil goes, 2 cylinders go down, but the engine will still run.... badly.
Old 01-02-2008, 01:29 AM
vgames33 vgames33 is offline
The cavalier does use two coils.
Old 01-02-2008, 02:19 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
I'm guessing its the coil. It can make visible spark, but just because you can see it doesn't mean its enough to fire the fuel.
You can test coils with an ohmmeter. Check with a tech manual for your car, but to give you an idea you can start by testing both coils and seeing if they're different. I would also try swapping coils to see if the misfire moves to 2 and 3. If so, you know its the coil
Dragging people kicking and screaming into the enlightenment.
Old 01-04-2008, 05:16 AM
UncleBob UncleBob is offline
AF -Advisor
with a DIS ignition setup such as this, the return path for the coil is from one coil post to the other coil post. What this means is, if you have a very bad connection, open circuit etc for either cylinder, you can cause misfires on both cylinders, even though only one cylinder has an obvious problem electrically
Could be a coil of course, but don't jump to that conclusion because you have misfires on both cylinders
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 01-05-2008, 12:26 PM
534BC 534BC is offline
1 and 4 are at ends, right? Is there any sharing of intake,carb bore, ect? it could be something common to both cylinders as well as the ignition components.
