Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 12-29-2007, 07:59 PM
ldrroch ldrroch is offline
tranny p1762
trans wont shift and when is shifting has no pick up also briging up code p0138
Old 01-22-2008, 07:10 PM
99 Neon R/T 99 Neon R/T is offline
Re: tranny p1762
well the only tranny code i could find like that was p 0762 which is shift solenoid circut c stuck on.p0138 is o2 sensor circut high volts bank 1 sensor 2.The wiring harness for the tranny runs down the driver side inside of the frame rail along with the o2 sensorwiring.That may be a good place to start troubleshooting.Check for loose or broken wires.If not you may have a bad valve body and o2 sensor.Good luck I hope it is a quick fix for you
If it aint broke fix it till it is.
Old 01-27-2008, 05:39 PM
xj31 xj31 is offline
Re: tranny p1762
p1762=governor pressure sensor offset volts too low or too high
Old 05-08-2010, 03:20 PM
srjeeper srjeeper is offline
Re: tranny p1762
Anyone know how to fix this problem.I have this code coming up on my 02 Dakota.It pulls away in third gear most of the time,but sometimes it sticks in first gear.
EDIT: I've done some searching and reading and figured out that,when it stays in third gear this is a safe mode.Now I figure I have to change the governor pressure sensor and transducer.I can do the job myself I just don't have any info on where the parts are.My question now is where are they on or in the tranny?
Old 05-08-2010, 10:02 PM
troy1 troy1 is offline
AF -Advisor
Re: tranny p1762
First off what engine to you have? 4.7L will be different.
***3.9L, 5.2L & 5.9L only***
Buy the new parts and pull the pan pull four 7/16 bolts and two T25 torx bolts to remove the solenoid aluminum block and remove the two items and replace. Don't over tighten the T25 torx hand tight with a screw driver is all they need.
Old 05-08-2010, 10:08 PM
Re: tranny p1762
Yeah sorry I didn't specify the motor details,it's a 2002,2wd, 3.9L.
Thanks in advance.
Old 05-08-2010, 10:12 PM
AF -Advisor
Re: tranny p1762
Ok this will work with the 3.9L also
Old 05-08-2010, 10:30 PM
Re: tranny p1762
Sounds easy enough,Thanks again.
