Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 12-28-2007, 03:00 PM
xhale xhale is offline
Question 99 GM won't start
99 GM, 70k miles
This has me totally confused. The car hasn't been driven since the 24th. All seemed fine then - it turned over easy, drove like a dream.
This morning it wouldn't start. When I turned the key the interior electronics just die and the engine clicks. The interior lights don't slowly dim (like you'd imagine with a dying battery), they just cut off, and after I stop trying to get the engine to turn over, they come back on. From what I've read, this implies a problem with the starter, not the battery.
After clearing a little crud from the positive battery terminal, I've hooked the car up to a trickle charger, and after an hour or two of charging, the engine turns over a little then starts clicking again. This seems to imply that it is the battery after all.
So I'm confused. After searching a lot of posts I can't narrow the problem down any further than the starter or the battery.
I'm not at all a car mechanic, so any advice is appreciated.
Thanks!
Old 12-28-2007, 06:50 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 99 GM won't start
If charging the battery helps, replace the battery and be sure all the cable connections are clean and tight. How old is the battery? If it is 4 years or older, replace it.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
